ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Telemetry is logging twice, not all the time , do we need that much logging
    Sort on RAD
    2014-08-30 08-25-31.bin
      Richard,
      Thanks for the report.  It seems the RADIO dataflash log message is written whenever the vehicle answers a request from the ground station for the status (MAVLINK_MSG_ID_RADIO or MAVLINK_MSG_ID_RADIO_STATUS).  That's a bit inconsistent with how we write all other dataflash messages so I'm not overly happy with that but putting that aside, it means in the short-term it's likely caused by the ground station asking for both messages.  I guess you're using the Mission Planner?
      • Got the same result without Mission Planner
      • I use Mission Planner 1.3.10 Build 1.1.5369.11976
  • yesterday I tried rc10 after my last crash and everything seemed fine except some variations in altittude in alt. hold and pos. hold mode, I guess it's a baro problem, could it have been damaged from my last crash?
    • Here's the log in case someone can help me this time :)
      Alt. Hold Parque.log
      https://storage.ning.com/topology/rest/1.0/file/get/3702521867?profile=original
        Esteban,
        It's definitely vibration levels.  Jonathan Challinger has recently added a new automated test of IMU variations between the two accelerometers on the Pixhawk and it seems quite good at catching the problems.  It claims a 1.13 m/s/s difference between the two IMUs.
        3702669003?profile=original3702668789?profile=originalBy the way, you may find that setting AHRS_EKF_USE to "1" makes it perform better because the EKF is better able to deal with vibrations.  The EKF is still experimental however so the safe official advice is to try and reduce any vibration in the frame.
  • today I try again rc10 with strong wind, just impressed, first time that I can fly with this conditions in stabilize mode for the moment., Land is working well again.
    • Has PosHold been renamed to Position between RC9 and RC 10 ? I had been using flight mode 16 "Pos Hold" and now it seems to no longer exist ??
        Sam,
        Any chance you've re-installed the mission planner from the .msi?  if "yes" then you've got an old version of the mission planner.  I think on the "Help" screen in MP there's a "check for updates" button that should hopefully get it up to a more recent version.
