ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • Rainer das ist Thüringen :-)
  • Can anyone tell me why my heli isn't landing?  I have a simple flight plan with Takeoff, a couple of splines and an RTL. The winds were gusting up to about 25kt and this was the first flight on 3.2rc12.  I did the flight plan twice.
    The first time it loitered at home for about a minute (should be 4 sec) before landing.  The second time it loitered until I had to take the aircraft for batteries.   I tried again later with the same results even in RTL mode.
    When I looked at the NTUN. DPosX/Y are not recorded at line numbers 46K and 70k from reaching home to shutdown.  CTUN DAlt has a steady alt.
    Any clues?
    5.BIN
    https://storage.ning.com/topology/rest/1.0/file/get/3701852558?profile=original
    • I've seen an issue wherein if you set the WP radius to 1 (I am working in units of feet and feet per second), save a flight plan, and then reload it, the MP resets it to zero when I reload it. If I try to fly the flight plan without checking that the WP radius is not zero it will not properly execute the flight plan (it takes off but does not move), or when I try to RTL it will not land. If I remember to set the WP radius to 1 it works perfectly. For what it's worth, my experience...
      • Thanks.  I've seen this problem too.  I think it's a rounding problem.  This issue usually shows itself on takeoff, though.  It'll take off and climb to altitude and them stay there, unable to reach the impossibly small target, indefinitely.
        It happened to me again, today; once out of the two flight plans I did.  Can it be because of high winds? That when it shows.
    • Hello
      The problem I had.
      I deleted the SD card, and OK with RTL
      • Yeah, it seems to be working fine now.
      • Thanks, I'll try it.
    Sorry, I haven't been answering too many reports or support questions in the past 3 days but I'll be back reviewing the build-up from tomorrow.
    • Please can you have look at my Question
    • no problem Randy, take your time.
