ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • yes. i do hope something works out for boaters like us. I don't really like to ignore all my error messages in MP.
    • I had the same may have moved it while plugging in power if it was calibrating it's self not shure but unplugged plugged in again let go quick and then no problem
      Stuart
  • Loaded 3.2rc12 on my old small DIY tricopter with an APM 2.5 yesterday evening. Very little tuning was done before the auto flight (just plugged in a few old values I had for that frame). Zip-tied the SJ4000 directly to the frame, tossed a few spline waypoints in and let it go. It only 'jerked' at about half the waypoints so it is possible the wind gusts had something to lend to it. Overall very smooth and it has never flown better. Great job Dev's! http://vimeo.com/108748302
      Michael,
      Thanks for the feedback.  Getting rid of the little jerks as it goes through waypoints has been a bit of a struggle.  We think if the waypoint speed is low-ish (like 5m/s) they won't show up but as you go faster they appear.  For AC3.3. I'm sure we will get rid of them completely.
      • Would be so great to get rid of the jerks in AC3.2
      • I'm definitely experiencing that. My WP speed is set to about 35kh and even if I'm careful to not do S patterns, I still get jerks on the yaw. I'm doing FPV so it's very noticeable.
      • Randy, is there a feature request list for post 3.2 releases anywhere? Thx. So far RC12 is treating me good. Thx for all the hard work!
  • Randy, do you mind taking a look at my message on the previous page. I'm thinking it's an auto landing triggered by GPS but am not sure that is showing up in the log. It's never happened before. Only with rc12. Did some checking get more strict on GPS health in rc12? Up until rc10 I never had this happen.
  • Could some one explain the Altitude Parameter on the DO_SET_ROI please? if Spline Waypoint 1 is 10 M and SET_ROI is 8m and Spline Waypoint 3 is 10 M will that produce a Dip in altitude? or is that parameter largely ignored? Also still trying to Clarify the Cicle Radius if it is in deed meters or centimeters. The Mission Planner Full params Shows it as Meters.
    thanks in advance having a great time flying RC 10, just upgraded everything to RC12 and hoping for a sunny weekend. KUDOS all around Dev Team!!
      Circle Radius is in cm (older FW it's in m)
      const AP_Param::GroupInfo AC_Circle::var_info[] PROGMEM = {
      // @Param: RADIUS
      // @DisplayName: Circle Radius
      // @Description: Defines the radius of the circle the vehicle will fly when in Circle flight mode
      // @Units: cm
      // @Range: 0 10000
      // @Increment: 100
      // @User: Standard
      AP_GROUPINFO("RADIUS", 0, AC_Circle, _radius, AC_CIRCLE_RADIUS_DEFAULT),
