ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • This reply was deleted.
    • Yes. You dont loose much, maybe 1m from what i have seen. It's just that the barometer gets confused due to the rush of air as you fly fast. Compensate with a little throttle and you are good to go.
      Randy said that in a future version of ArduCopter some formulas might be implemented to compensate for the barometer confusion.
          If you have a log that would help me determine the cause.
          My off the cuff guess is that the alt-hold controller simply can't maintain the altitude with the lean angle that's being requested by the pilot.  This is perhaps the likely cause if the vehicle doesn't have this issue Loiter mode where the horizontal controller is careful not to ask for more than the frame can provide.
        • Yes I get that too. It has been a bit frustrating for me as I spent a great deal of time building a waterproof quad so I could get low level high definition video over water but because of this issue it was impossible. The copter would go up and or down 20 meters on high speed runs. I was better off in stabilize mode. I left the battery door open to see if it was the equalization vent but it was not. What would happen with me is on a high speed forward run it would drop to the point I have to increase the throttle then as I slowed down it would shoot up 20 meters. It seems like there could be a firmware solution for this. If forward speed created a lower altitude seems like this could be automatically be adjusted. Might not work going in reverse real fast but I'd say that would be a decent trade off.
  • i test arducopter 3.2 rc12
    apm
    2 different gps with nmea output (38400 baud VTG GGA 5Hz)
    in mission planner show "no gps"
    blue led off
    i test different gps settings 1 (auto), 5(nmea) - no difference
    when i use AC 3.15 firmware - all work fine
      • i test gps modules separatly
        as primary gps at APM controller
        NMEA protocol on APM is not work
          Alexey,
          Yes, you're right.  Due to flash space constraints we dropped NMEA and SIRF GPS Support in AC3.2.  It's possible to re-enable them if you're compiling the code yourself.  It should work by simply commenting out this line from AP_GPS.h:
          #if HAL_CPU_CLASS < HAL_CPU_CLASS_75 && defined(APM_BUILD_DIRECTORY)
              #if (APM_BUILD_TYPE(APM_BUILD_ArduCopter) || defined(__AVR_ATmega1280__))
          //        #define GPS_SKIP_SIRF_NMEA            <---- comment out this line.
              #endif
          #endif
          Although in my testing I found I needed to comment out this line in AP_GPS.cpp where the GPS_SKIP_SIRF_NMEA definition is checked.
          These two GPS drivers consume 4k of flash and we're simply out of space on the APM2.  We could potentially create an alternative set of binaries for people to load themselves with the "Load custom firmware" link of the mission planner.
          • Randy,
            thank you very much for your help!!!
            of course i will compile hex file for myself and for my friends
            all modules ublox, sirf & mediatek  is support nmea protocol
            maybe select it by default for compatibility in next relises ?
