ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • With everyone talking about calibration and ways to do it does anyone have a set of ranges we should be looking for? There are many ways to manipulate getting numbers but which ones are right? Is it still anything below 250 is good?
  • This reply was deleted.
      You need the beta of MP to  see Pos Hold
        Craig,
        I just checked and the "stable" release of MP right now is 1.3.14 build 1.1.5436.9174 while the Beta version is 1.1.13 build 1.1.5432.12651. Not sure what's going on there.
        Nathaniel ~KD2DEY
          That means Michael pushed a change to Master but has not updated the Beta branch in github
        • FYI.  I put in a request last week and the latest MP now displays the MP and Aircraft software versions in the header of the MP when connected.
          MP is compatible with every MAVlink enabled system and can detect which version of code is running in a vehicle if the vehicle sends it to the planner.  MP does track some features on a vehicle by vehicle and version by version basis.  That is why it asks what version you are running prior to a compass cal or accel calibration but in general it is very difficult to track what features are enabled in various versions of the code and it is not really a very good investment of Michael's time to write that kind of code.
          MP pulls features from automatically generated XML files with either stable or Beta tags associated with them.  Currently Copter 3.2 still has the Beta tag on it and so you need the beta version of MP to access the beta parameters descriptions but if you are a sophisticated enough user to be loading and testing beta firmware then should be a sophisticated enough user to go to the parameter description
          http://copter.ardupilot.com/wiki/arducopter-parameters/#Flight_Mode...
          look up the parameter number for Pos hold and enter it into the field.  If you are not sophisticated enough to do that then you are best off spending enough time to become that sophisticated before operating beta code.
          By the end of the week 3.2 will be a full release and the beta tag will be removed and the Stable release of MP will display all the modes automatically.
            Although I'd say that AC3.2 is no longer beta code..
            I'll be promoting AC3.2 to replace AC3.1.5 by the end of this weekend in any case.
            • Great news, then I'll go for 3.2 on my Tarot T180 build :)
              We've got a plan to add a parameter to AC that holds the version number so hopefully we will get to that for AC3.3 and that'll certainly make life easier for the ground station developers.
