Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
I have a problem that I cannot arm my copter any more.
There are no prearm errors, it just refuses to arm.
I had some problems with a (pitch/roll) gimbal on my 9xr Pro transmiter, that I sorted out - a loose potentiometer.
After fixing it I did the radio calibration and the problem showed up.
I have tried loading some default parameters, with them I could arm, but then I had another problem.
I could disarm the motors (the red light flashing) but the motors would continue to run at slow speed.
If I change the RC3_MIN the motors will stop but I can't arm again, so it seems to me that there is a problem with my parameters, but I not able to sort it out where.
I am attaching the params and logs (on the bench).
Thx.
MyBadParams.param
2014-11-22 18-21-42.rlog
2014-11-22 18-21-42.tlog
Strangely enough, the problem went away this morning.
I tried to arm it and succeeded?!
The only thing that's different from yesterday is that I didn't connect it to MP.
About 2 weeks ago it came out of beta.
It is still Beta but in the final phase they are being extra careful before it's the official release
According to this it is not yet the stable release:
http://firmware.diydrones.com/Copter/
thanks in advance
yuvraj
Copter shot straight up full throttle while it alt hold I immediately hit stab to come back down. 3.2 rc 14. never had this in rc10 only thing changed other than rc 14 that I can think of is new esc's. Love 3.2 butter smooth until now. If anybody could look at the log I would appreciate it.
132.BIN
Climbing in Alt hold is a common symptom of excessive vibration. The auto analysis quickly confirms that is the case with this log. Perhaps you have something hitting the autopilot.
Log File C:/Users/Navigator/AppData/Local/Temp/tmpDD1E.tmp.log
Size (kb) 9632.8583984375
No of lines 132504
Duration 5 days, 14:45:06
Vehicletype ArduCopter
Firmware Version V3.2
Firmware Hash c8e0f3e1
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = UNKNOWN - No ATUN log data
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = FAIL - Large change in mag_field (57.72%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: GPS
Test: GPS = FAIL - Min satellites: 0, Max HDop: 99.99
Test: IMU Mismatch = WARN - Check vibration or accelerometer calibration. (Mismatch: 1.42, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = GOOD -
Please start with the auto analysis tools first as it can save everyone a lot of time.
Also please review the log yourself and look at the DAlt and the Baro Alt and you can see the effects of the vibration on the vehicle
http://copter.ardupilot.com/wiki/downloading-and-analyzing-data-log...
Also look at accelerometer X & Y values. There is a pretty big offset between the x & y accelerometers. Did you bang or move the autopilot?
Am I looking at / reading this right? See pic
I only recently got the PC version of Mission planner I've been using the Mac version APM Planner which doesn't have that auto analyzer. So I will for sure try that out. Not sure why it says zero sats it was over 7. I don't like that compass issue either. It's a 3dr compass / gps on a mast so not sure what more I can do with that. I recalibrated twice. I know what you mean about vibration but I'd be surprised if it was that. I've had that before and it's a constant thing and the copter kind of just doesn't hold alt very well. This holds alt perfect! No issues then it's like flicking a switch it shoots up. Did the same thing here [ see new log ] but not as bad. Not saying your wrong just I'd be surprised if vibration acted that fast and so abrupt when it was perfect otherwise. Thanks for the help though!! I'm sure it's a set up issue one way or the other. I did re-secure the pixhawk when I did the esc's maybe it's loose or bumping something.
133.BIN
23
24
25
26
27
of 262 Next
