ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • You may get a better answer from someone else but here's my guess. I've had a sync crash although not in this circumstance. My guess is the FC gave the ESC enough of a throttle blip when you switched modes to cause the sync failure. Now I always do a sync test on any new combination of ESCs and motors to be sure this is not an issue. If you have a servo tester it works best but even your transmitter will give you a pretty good idea. Strap the quad down (very securely at each motor) and power up. In stabilize mode flail the throttle on you TX and see if you can get the motors to loose sync. The servo tester will give even sharper acceleration.
      • Thank you for your reply, It does seem like a sync issue. I just cannot find another point of failure, as I have followed the WIKI to a letter, and followed all the pre-flight and setup perfectly.
        We are quiet bummed about this crash.
  • Just curious and I may have forgotten, does the pixhawk read sonar or Lidar (if equipped) information when landing?
      Doug,
          Yes it does but perhaps not quite as you'd expect..  You know how when landing from a high altitude it descends at about 1.5m/s (WPNAV_SPEED_DN) but then around 10m it suddenly slows to 50cm/s (LAND_SPEED)?  With a lidar attached it will reduce it's descent to the lower speed the moment it senses something below (with the lidar/sonar).  Now that you bring this up this could be a bit annoying with a 40cm lidar!  Maybe we should fix that.
      • Thanks for the info. Definitely think the code should be adjusted to not start lower speed descent from 40m up would be a bit crazy.
  • Thanks Randy, I'm much more confortable now to go on with 3.2.
  • Hi, I tried to make an adjustment in Loiter PID but  "HLD_LON_P " didn't set. Going to the full parameters list that item is missing. I'm using APM 2.5, latest MP and arducopter 3.2. That problem only occurs with 3.2, going back to 3.1.5 that's OK. I found the same problem reported here before but I couldn't find any comment. Does anybody know about it? Is it normal in 3.2, should I worry about it?
    Tks,
      Marcio,
      If you can update HLD_LAT_P then it should be fine.  We removed the HLD_LON_P because there shouldn't be any need to have a different P value for Latitude direction correction vs Longitude.
  • You were lucky you switch to Stabilize when you did.  The Throttle Out went to maximum and stayed there until you switched to Stabilize.  The vibration seems to have happened after that so I don't think that did it.
    • With AC I learned a long time ago stabilize = my friend :)
      It happened during pos.hold and I switched to alt.hold but that didn't help. The order of events you are saying is interesting, this would explain why vibes were only on the Zaxis. Will double check again, but would definatelly appreciate a reply either from Randy or one of the devs involved in pos.hold.
