Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Nice video. Great to see spline in action.
Randy,
I read the wiki and it said in 3.2 DO_SET_ROI will hold the nose without entering multiple commands, as shown this video it did just that. Problem is I have clue how to cancel and get it to return it back to normal yaw(nose) position. So once set seemed as it was always set. How do I cancel the DO_SET_ROI? Do we need an END_SET_ROI?
http://copter.ardupilot.com/wiki/mission-command-list/#Do-Set-ROI
(Note: in AC3.2 it will be possible for DO_SET_ROI without entering multiple commands).
Thanks, Ed
IIRC, a DO_SET_ROI with lat,lon set to 0,0 cancels the command
Peter,
Txs for the report. The EKF shouldn't affect the autotune so you should be able to stick with the previous PIDs. Generally the EKF (which only runs on the Pixhawk) should perform just like the existing DCM+inertial nav (it replaces both) although it should be more resistant to vibration and other sensor noise.
Same question I posted here earlier but there's no response, even from the dev team.
@christian , thanx for the list. i did not realize that the sunrise 20A ESC have SiLab processor. I have ordered sunrise 20A BLheli firware ESC. I am glad the ESC in in this list. the list should be updated regularly since there so many brands of ESCs in market. I still think the ESC sync with pixhawk is a major issue and could be a cause to some unexplained crashes. honestly, i never had a crash in last two years. this is my first crash (really bad) and i would try to eliminate this cause forever.
Ravi...forget about expensive ready to go solutions...
1.Buy this cheap programmer from HK $9.23
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
2.Open your ESC heatshrink
3.Solder 3 programing servo wires,
this is your ESC from inside,and where to solder(white,red and black circle)
http://www.helifreak.com/attachment.php?attachmentid=481794&d=1...
http://www.helifreak.com/attachment.php?attachmentid=481793&d=1...
(you can secure them with hotglue) and let them stay there for future update and programing
3.Download BLHeli program
https://www.mediafire.com/folder/dx6kfaasyo24l/BLHeliSuite
NOW FLASHING
do it in this order;open blheli,connect ESC to your lipo first,conect soldered pads to HKprogramer second,connect to your pc usb,CLICK CONNECT, find your ESC on list....BE AWARE IF YOUR FLY MULTI LOAD MULTI SOFTWARE NOT HELI or governor
FLASHING esc IS EASY AND IT TAKES 1 SEC....ONLY PROBLEM IS TO SOLDER WIRES TO SMALL PADS ON ESC,NICE TINY SOLDERING TIP OR smd will help you a lot...
CHECK HERE for further links
https://docs.google.com/spreadsheet/ccc?key=0AhR02IDNb7_MdEhfVjk3Mk...
Gary,
Thanks for the report. A few others have made similar complaints about the slow-response in yaw. There are some parameters starting with ATC_ (i.e. ATtitude Control) that could be increased and might improve this but basically we need to increase the default rates probably. We should be able to sort this for -rc3.
@Felix, it is better to open here to show my understanding.
As you already know a lot on this area, Pixhawk consists from PX4FMU-V2+PX4IO-V2.
The firmware for PX4IO-V2 that is provides by ArduCopter 3.1.X dose not support THFSS-Air.
That of ArduCopter 3.2 rc2 support THFSS-Air.
Both ArduCoter 3.1.X and ArduCopter 3.2 support S-FHSS could handle S-BUS receiver FASST.
If you want to use telemetry feature with T10J-R3008SB then you need everything.
1) Bind T10J-R3008SB with THFSS-Air for telemetry
2) Connect Pixhawk R/C input port and R3008SB S-BUS
3) Load ArduCopter 3.2 to Pixhawk
4) Calibrate R/C on Mission Planner
5) Connect Futaba CAR-VIN-700 external voltage cable to your R3008SB
That is all.
I hope the release of ArduCopter 3.2 includes new S-BUS communication feature;)
Thanks a lot Jiro
239
240
241
242
243
of 262 Next
