ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • From the pictures it looks like it's neo 7 have received it?
      • I doesn't received it. I still wait. The pictures shown a NEO 7M (I think) with 5883 (printed on it). But I think, the description is correctly and only other pictures used...
  • Randy,
    Thanks for the clues on the FS_THR_VALUE.
    I'm using a FrSky Taranis adn X8R receiver. My RC3_MIN is 982
    The default FS_THR_VALUE was 975.
    I had to set the FS_THR_VALUE to be 971 to stop the 'check FS_THR_VALUE' warnings. Note that when I set it to be 10 below RC3_MIN (972) I Still received the warning.
    If FS_THR_VALUE must be 11 or more below RC3_IN, perhaps part of the Radio Calibration Routine should automatically set this value or provide a warning if the values are out of a valid range?
  • Hi Randy, I have been flying with APM2.6 &  AC3.2RC5, since it was released and did almost several hundered flights and had never any crash due to firmware ( I had crashes due to my mistakes). Do you still recommend me to upgrade to AC3.2RC7 ?  In 99.9% of my flights, landing was only by the firmware and not myself. Was its only my luck that I had no crash due to firmware ?
      Rana,
          Great to hear things have been going well.  Yes, the problem with the landing check in -rc5 could affect anyone so I'd recommend upgrading to -rc9.  The number of changes has been slowing down in the later release candidates so it's hard to imagine that you'd be worse off with the later versions.  The only thing you may not appreciate is the stricter landing check especially if you land in AltHold, Loiter or PosHold a lot.
      • Thanks for the clarity Randy !
  • Well I tried my hand at Droid Planner/Follow Me and my Yaw behavior didnt respond as it does when flying a mission (Turn toward next way point) any suggestions  i am all ears
    https://www.youtube.com/watch?v=fIZwR1gapMI
    • Hi Thor, was the follow-me working with Andropilot ? I tested recently the beta of Andropilot and it did not work at all.
      • no @Rana it was not working for Andropilot at all for me either
        • Were you in "Guided" mode ?
