Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Waladi,
I'm really not sure which IR shutter trigger you're using but I guess if RC10 worked it must work based on a pwm signal. RC7 and RC8 also produce pwm signals (as opposed to digital high/low signals) so they should work but (as mentioned above) RC7 and RC8 output at 490hz (as opposed to RC10 and RC11 which output at 50hz). I imagine the IR shutter trigger you have doesn't like that high output rate. So I'm afraid I don't have a solution except to stick with RC10 and RC11 somehow or try another variety of IR shutter trigger.
Brandon,
Looks like GPS glitches. Quite a few of them. Maybe there's some FPV equipment close to the GPS?
Excuse my ignorance but what is guided mode exactly? Is that simply a reference to a 'long press' on a touch pad using DP that is essentially a 'go to here' command or is there more to it than that?
Richard,
Guided mode's description is on the wiki here but in short, it's a mode which gives the ground station direct control of the position of the vehicle. It's used for "follow-me" and "fly to here" features in MP, DroidPlanner, etc.
I went out and tried APM 3.2 last night on my tricopter. Autotune, Alt hold and Loiter all work.
I tried guided mode from a android phone but it didnt move, it stayed in loiter. Is there any known issues with this flight mode?
Thanks for the hard work
Paul,
There was a change in AC3.2 so that we now insist that the vehicle is in Guided mode before it starts accepting follow-me (i.e. position) requests. I believe AndroPilot and DroidPlanner have been updated to handle this although I haven't checked myself. You're using a recent version of one of these two?
Not to hijack this thread but, in the latest Droidplanner i was able to get Follow me to work with out switching to Guided Mode. Once follow me is clicked, the aircraft automatically switched to Guided Mode. i havent been able to get Andropilot to work in Guided Mode/Follow me even when manually switching to Guided Mode. Droid Planner did work pretty good tho but it did have issues with RC7. i am waiting on rain to go away to try again...or i might be building an Ark Soon and using my drone to find animals to board said Ark :P
Yes it was the newest version of DroidPlanner 2. I havent set guided up as a flight mode, would i have to? or would selecting guided from the interface be enough?
Why was this changed? before you kept the copter in loiter, long press the screen at a point on the map and it asks if you want to go to guided mode, wasn't that check enough?
Paul
Are you talking about guided mode only, or follow me that uses guided mode? They're two seperate things, follow me automates the sending of guided waypoints. With just guided mode only you have to put a guided waypoint down yourself. With follow me mode the android device sends updates to ArduPilot by itself.
104
105
106
107
108
of 262 Next
