Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
fabio,
Ok, thanks for the report. Your flight has uncovered a stupid error in the dcm-check code. It's not correctly clearing the counter when the heading becomes good. This means many small heading errors will trigger the LAND.
I'm afraid I will need to push out -rc14 tomorrow. Really sorry about this everyone.
Hi Randy,
I think I had the same problem with the fw 3.2RC13 failsafe dcm while I was flying the quad landed alone.
log has many errors Ekf failsafe as you can see in the picture.
regards
Fabio,
Any chance you could provide a dataflash log instead of a tlog?
If you're using the 3DR compass: http://copter.ardupilot.com/wiki/common-installing-3dr-ublox-gps-co... otherwise here: http://copter.ardupilot.com/wiki/common-external-magnetometer-for-i...
You might be able to do it in the parameters. You can change the COMPASS_ORIENTATION parameter and then bench test it to see if it's correct. The settings 4, 6, 8, 10 etc might work for you.
I mount my pixhawk underneath and upsidedown (roll 180). I have my compass/gps right side up (normal).
My parameters are AHRS_ORIENTATION 8 and COMPASS_ORIENTATION 0.
Leonid,
No, you'll need to set the orientation yourself. On the MP's Mandatory Hardware >> Compass screen you'll see there are 4 options. Pixhawk/PX4 is just one of them and that assumes you're using a Pixhawk with or without an external compass (it can detect if one is attached or not) BUT it assumes that if it's external it's in the standard orientation. If it's not then you'll need to select the "Manual" option at the bottom and select an orientation.
Randy, did you see the logs of my second crash, which was exactly same as on previous day ?
I attached there, the telemetry log, Flash log and firmware copy of mega2560 read via mission planner for your analysis.
Today also I tried to repeat it again but this time with the help of a person I hold a cloth bed sheet under the loitering quad, this time also, after touching follow-me from the Droidplanner 2, all the motors stopped as earlier and the quad fell on the holded bed sheet and no damage to the quad.
Randy, see not only me but many people encountered same problem and reported so it's enough evidence for you to believe that there is certainly a nasty bug in the code.
I think that the microcontroller ATMega2560 getting reboot while jumping to execute guided command when the quad is in air and loitering.
I also tried to simulate the condition while holding the quad in hand, arming it and putting in loiter then touching follow-me from droidplanner 2, in this state the motors did not stop, I repeated and did not observe motors stopping in air while holding the quad in hand.
Today, I had two flights with AC3.2_RC12 with APM2.6. In first flight, I tested stabilize, Loiter and RTL, it did well.
In the second flight, I took off in Loiter and at 3mt altitude, using latest DroidPlanner 2, while, the quad was in loitering, set follow-me from the phone.
Within a second, of touching follow-me, all motors were stopped and the quad fell like a rock. Attaching the flash and telemetry logs.
In telemetry log, Quad arms at 92% of the telemetry log file.
Auto analysis report:
Log File C:/Users/Narpat/Desktop/Telemetry Logs, Videos, EEPROM & Flash uploads/Flight Logs/Flight & Telemetry logs of 25.10.2014/2014-10-25 16-18-37.log
Size (kb) 85.82421875
No of lines 1386
Duration 0:00:19
Vehicletype ArduCopter
Firmware Version V3.2_RC12
Firmware Hash
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = UNKNOWN - No ATUN log data
Test: Balance/Twist = GOOD -
Test: Brownout = FAIL - Truncated Log? Ends while armed at altitude 3.50m
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = WARN - VCC min/max diff 0.302v, should be <0.3v
2014-10-25 16-13-48.tlog
2014-10-25 16-18-37.bin
Wesley,
I had a look at your logs and it also looks like a brown-out. In this log though we're slightly lucky in that we can clearly see the main battery voltage dropping to 8V in the last 0.5sec of the log. Obviously it's not a "lucky" situation that the vehicle crashed but "lucky" in that it points pretty conclusively towards the cause of the problem (a power issue). Can you describe how the board is powered?
Same thing happened to me, crash after motors just stopped, with the logs truncated. Almost identical to the two above.
http://ardupilot.com/forum/viewtopic.php?f=25&t=8769
56
57
58
59
60
of 262 Next
