Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Kristian,
Could you include the log of your good flight as well?
In the 156 flight, It looks like the vehicle's heading estimate is off which is leading to the toilet bowling. I think this because the EKF and DCM disagree about the heading by 50~60deg.
It's slightly unclear to me whether it's the compass calibration (ie.. offsets) that are bad or the gyro bias. Hopefully by looking at your good-flight's logs we can tell.
By all means. Here's the previous flight (literally minutes before on another battery pack) which didn't seem to have any issues, that I could tell at least.
155.BIN
Kristian,
Sorry for all the posts but Tridge and I reviewed the 158 log in which the vehicle crashed just as the EKF was engaged. We found a bug that could cause invalid (incredibly large) positions and velocities to come out of the EKF for the first loop that it's engaged. We've got a couple of fixes that we will release with AC3.2-rc12 tomorrow. I've updated the warnings in the main part of this discussion to warn people about switching the EKF on and off with the ch7/ch8 switch.
It's a bit hard to directly tie this to your crash but expect and kinda hope that it is.
Really sorry about your crash.
So it looks like I'm back up and running now. Took it for a flight, and it seems good. Only issue, rather odd one at that, is that the props don't spin when armed. This is a new behavior.... they always spun slowly before.
So I checked the parameters, mot_spin_armed is set to 70 and thr_min is 130. So they SHOULD spin. I recently re-calibrated the ESCs and also re-did the radio calibration (not sure if that had anything to do with it). But I'm stumped why they don't spin when armed. They also don't spin when the throttle is at minimum, so in testing (with props off), I'll put it into stabilize or alt hold and at throttle minimum, the props don't spin at all. Move the throttle up a tiny bit and they come to life and it otherwise seems to fly fine. Will do more testing today though.
Any ideas? Should I try and do another clean install of AC?
+1
I'm seeing the same thing on my Y6.
Randy,
I wanted to post to this the other day when it was first posted. Could the issue I had here: http://diydrones.com/forum/topics/arducopter-3-2-beta-testing?comme...
be the same thing or related? Mine happened when turning EKF off and I believe I had it on channel 7.
George,
Thanks for bringing this up again. It definitely could be. It looks nearly identical in the logs except that in this case, as you say, it happened as you turned EKF off (while for Kristian it happened when EKF was turned on).
Your vehicle falls forward and left (instead of Kristian's forward and right). Also looking at the raw motor outputs Kristian's front right motor stays at max the whole time until the crash while your front-left motor recovers. I'm guessing a bit but the shock of the crazy number could lead to a sudden change in the request to the motor which could lead to an ESC sync issue. Maybe your vehicle's motor/esc recovered by Kristian's did not. It's a bit hard to say.
Thanks for the response Randy.
I won't rule out sync issues however I have spent many hours working on sync issues from when I had my hex with the same motors and esc's. I switched all of my esc's over to BlHeli firmware from SimonK along with strapping the quad down to the table to see which settings eliminated the sync issues. From the testing that I did with correct timing settings I could not get them to go out of sync. Even using a throttle hold switch to make the pwm signal instant to eliminate any delay from moving the throttle stick as fast as I could.
I guess it could be possible that there is a sync issue as I am sure the signal from the pixhawk going to the esc is faster than a signal coming from the radio -> rx -> pixhawk -> esc. Testing it to that extent is beyond me.
Kristian,
I've had a look at the 158.bin log in which it suddenly crashes the moment that EKF is enabled. It looks like a mechanical failure but more specifically I suspect a ESC sync issue on the front-right motor because the vehicle suddenly rolls right (+ve roll) and forward (pitch goes -ve). Also when looking at the motor output this front-right motor goes to full (which means the attitude controller wanted maximum power from this motor) which means it was getting much less than it wanted/needed.
It's obviously extremely suspicious that this happens at exactly the moment that the EKF is engaged so I'll escalate to Paul and the rest of the devs to see if people can find something I haven't.
Kristian,
The good log (155.bin) has near perfect tracking of desired velocity to actual velocity and DCM & EKF only disagree by about 15deg (which is still a bit high actually) so the vehicle's heading is good. The gyro biases are very similar between the good and bad flights so I don't think it's the gyro that is the cause.
So this leaves us with the compass as the likely problem. I suspect it'll be incorrectly calculated offsets (you re-did the compass calibration after replacing the GPS/compass module?) or interference from the power wires (any chance you could share a picture of where the compass is mounted?).
84
85
86
87
88
of 262 Next
