ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
          @Paul,
          It was a safety issue.  Because of telemetry delays this kind of thing could happen:
          a) vehicle is flying in guided mode receiving position updates from tablet
          b) something goes wrong (GPS glitch), user switches to alt-hold mode on the transmitter to re-take manual control.  At the same time the tablet has sent an updated position request.
          c) transmitter mode change is processed first and vehicle momentarily goes into alt-hold
          d) tablet position request is processed next, flight mode is changed back to guided
          So the user has tried to re-take control but has been unable to.
          It's really straightforward for the tablets to send a set-mode-to-guided request before they start streaming position requests and I've warned Arthur and Kevin of this change and I'm actually very surprised that it hasn't been incorporated.  There should be no need for the user to set the flight mode to guided.
          Could you raise an issue with the DroidPlanner developers here?  Andropilot is here.
          If you have a log around that also might help.
          Thor, Thanks for the feedback.  that's helpful.
  • Hi,
    I cannot see the parameter I added using this explanation
    http://dev.ardupilot.com/wiki/code-overview-adding-a-new-parameter/
    although It compiles just fine !
      Itay,
      This sounds like a development question, can you instead email the drones-discuss@googlegroups.com?
  • hi all,
    i found cause of big offsets of pixawk
    who have very large offsets (above 500) - try to unscrew the steel screw in corner near connector  ADC6.6V
    • Thx Alexey, now my internal compass is actually usable :) less than 200. But I think rhis makes my pixhawk board movable inside the case, I will try to find a non-ferrous version of the screws and replace them all.
      • This reply was deleted.
        • lol, in my case those were some guys in China using a magnetic screw driver, I remember clearly that the screw in question would stick to my cheap non-magnetized screw driver on its own...
          maybe it is worth to let 3DR know that they should advise their hardware partners NOT to use magnetic screw drivers while assembling pixhawks.
            This is an interesting find!  I've checked with 3DR and "as of 2 week ago" the 3DR assembly guys were not using magnetic screwdrivers on the Pixhawk case.  If it's a clone board (sounds like it is) then there's really no relationship with 3DR and somehow someone would need to get hold of the manufacturer to pass on that info.
            • "as of two weeks ago ;) "  pixhawks are being made a for bit longer time now.  personally I have a clone, but my cousin has a 3dr version  after taking apart the cases I was not able to find ANY difference between the PCBs. does 3dr put them in their cases here in CA?
              • Oh and compass offesets are equally big 400-600 range. He got his back in February and I got mine in the end of July. The reason why I had the 2nd IMU issues is because I added to big piece of foam to cover baro and it touched imu so with even slightest vibrations it rubbed against IMU and produced false measurements.
