ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • hi randy, had been flying form AC3.2-rc2 to AC3.2-rc12. Did not come across any issue that could be noticed. did about 20 auto missions. only issue i get is when using 3DR GPS on pixhawk. The GPS looses it's satellite lock during flight. This DOES NOT happens when using the same 3DR GPS on APM2.6. it happened twice. i was able to get the bird back although. could this be a bad GPS?
      A lot of good advice here already, I would add that it's unlikely to be a software issue but rather interference from something on the vehicle.  It could even be interference from the flight controller itself although I haven't noticed the Pixhawk ever causing GPS interference myself.
      The way I track down causes of interference is I load up AC onto a board somewhere where I know I can get good GPS reception (my house is mostly wood so I can do it indoors at my desk).  Next connect with MP and display the HDOP value in the Flight Data screen's Quick tab at the bottom.  I then let the hdop settle and connect/disconnect things and look for an impact on the hdop value.  In general hot-swapping things is not a good idea but I make an exception during this kind of testing.
      Next you can determine if the interference is "radiated" (through the air) or "transmitted" (along the communication wires) by repeating the tests but attaching the devices to a second flight controller.
      Note that some devices only create interference when they're being used.  So for example I found the early prototypes of the LIDAR-Lite range finder disrupted the GPS signal but it only happened when we were actively requesting data from the sensor.
      • Randy, I too had issues with occasional fly-aways with Pixhawk (and EKF On) that never happened before with AMP 2.6, but I think I may be on to the root cause now. I thought it was GPS at first, but it seems maybe not now...
        With the APM 2.6 I never saw need to use the Compass-Motor Current calibration available in Mission Planner, because I never had a compass related issue on this frame (that I saw anyway), and the couple of times I tried to use anyway it I couldn't work out how to do it properly. So I ignored it after that...
        I finally did it again on the Pixhawk at Leonard's advice and was very surprised to find an interference level reading of 93% !
        Now with Leonard's help also, I ran multiple Compass-Motor Current calibrations with things like battery wires twisted, iron shielding added and batteries removed and extended away from the frame etc, and finally found  issue with the magnetic field from the Hobbyking Quadcopter Power Distribution Board I have used. Moving the GPS/Mag unit away from it dropped the reading dramatically, so the board needs to be replaced with something better.
        I've now built a new distribution board from double sided FR4 that should be better at neutralising it's magnetic fields, and am going to retest this weekend.
        I wonder if Ravi has checked the Compass-Motor Current interference level on Pixhawk ?
        Martin
        • A follow up to my post about the compass-Mot interference levels, and my home made distribution board.
          I made a new board the same size as the HK board but with + & - only on one side. It reduced the interference figure in the Mission Planner test from the original 93% down to 51%.
          A worthwhile change, but doing more than that would require new cables on the ESC's as the length was only just long enough with no twists in it.
          Martin
          PS. I have photos if anyone is interested.
          • This reply was deleted.
            • Yes, all advice says that is still too much (51% interference).
              I've 'fixed' it by retiring that frame now...
      • One thing I can't figure out is how is it that The Iris or the Phantom have the gps in such close proximity to the electrons yet it is fairly well established that for us home made quads the gps and compass needs to be on a mast? I moved mine closer to the frame and lost the quad soon there after. I don't know if it's related but I'm guessing it is.
        • It's not the gps that causes the problem, it is the magnetometer that has to be distanced from stray magnetic fields.
          On the Phantom it lives down on one of the legs ?
          • I wish I knew what they used. I bought some copper foil but it seemed to have no effect.
            • The copper foil, or any shielding needs to be grounded to work
              • Grounded to WHAT ?
                This topic surfaces, gets beaten to death, and surfaces, again, a few months later.
                If it is RF(radio frequency) interference, it will ONLY affect either the RX, or the GPS, or both.
                If you effectively shield those from the interference, you also effectively shield them from the signals, they are SUPPOSED to receive........
                So get rid of the cheapie vidcams and vid tx's.
                THAT is why all electronic devices are supposed to be switched off on passenger aircraft :-(
                The magnetometer is ONLY affected by CHANGING magnetic fields, that is why you have to do COMPASSMOT.
                So, that is why DJI puts the magnetometer on one leg, others put the mag on a stalk, far away from heavy current wires.
                Yeah, I've only been in the RF game for 40 years.....
