ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
                • Randy, thanks for your reply.
                  I can't see how a little more than 1 axis is enough and I get very inconsistent results on my Pixhawk. Often no more than one of the white dots is completed. It seems like quite a few others are having the same issue so it would be great if Michael could lengthen out the time or a least give us the option to go back to the old method for comparison. I'll be interested in your test results, also if you have a CSG  Neo 8 GPS unit could you test it. Unless I have a bad mag the calibration doesn't seem to work well with it and gives very large offsets (my big quad is grounded until I figure this out)
                • Hi Randy,
                  I took some flights after doing the compass calibration with the latest mission planner, when I ran the log analyzer the logs from the 3 fights all had a big fat FAIL next to compass. I can tell you with the auto-complete, I never get past 1-2 axis rotations.. I can't imagine it's enough..
                  I then re-did the compass calibration on my laptop which had a slightly older version of MP(1.3.10 i believe), where I did the compass dance until I had 800+ samples. 3 more flights today and no complaints when running the log analyzer.
                  I don't know if it's related, but I'm also getting an "IMU mismatch - fail  (Mismatch: 1.52, WARN: 0.75, FAIL: 1.50)" now which I did not have before - yes I re-calibrated accel.
            • I read on this or the other 3.2 thread that the calibration is down to mission planner, which makes sense to me.
              • So you are saying even if I upgrade to AC3.2, I will still use the older style compass calibration till I upgrade to one of the latest Mission Planners.
                Correct?
  • Hi,
    I was flying today with my quad and had strange issue with RTL, as soon i switched into RTL the copter descent fast and landed (nothing broke but i cannot find the reason why this happend. (it is the second occurrence on this quad) tried afterwards few times but RTL was normal !!!)
    could someone have a look at the attached log and tell me whats wrong ?
    Thomas
      Thomas,
      Logs??? Did you forget something??
      • upps.. file was too big and no error message :-(
        2014-11-15 15-51-43.rar
        • nobody :-(
            Thomas,
            Sorry, I should have replied earlier. When I try to download your .rar file I get an access denied error. :(
            3702830643?profile=originalI Don't know if others are getting the same thing, but that might explain why you're not getting any help. Maybe you should put the file in a DropBox or the like and post a link to it.
            Nathaniel ~KD2DEY
