Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Both compasses have high offsets. GPS modes need a good compass reading.
I'm sure this has been answered, but couldn't find it.
When attempting to download logs via Mavlink (usb), I get "error receiving log list". What is the causing that?
Thanks.
3.2
1.3.17
Hello Alex
Thanks for taking the time to help.
To answer a few questions,
Set PID's back to default
Their is foam over the Barometer sensor
Increased INS_MPU6K_FILTER to 10 the 20. Default 0. Noticed slight improvement
Note INS_MPU6K_FILTER set back to 0 for log
Throttle set to mid
Props balanced
Balance of copter good. Hung by string at mid point.
Still pulses in alt and loiter
Log attached Default + IMU
Hope this helps
Cheers John H
New Zealand
Please try this log
2015-01-19 19-49-15.bin
Logs attached ti
his time
Can you test by using a house fan or something indoors and see if it affects the altitude reading as you manually rotate the copter at different angles to the wind?
H1 all
I have a problem with POSHOLD.
I have set the quad up as best I can. It flies very stable in Stabilize mode. and is very responsive.
When switching to POSHOD it starts to bounce up and down. Motors quick accelerate and decelerate. moving copter about 100mm in either direction. I have set mid throttle as per log.
Log attached.
Cheers John H
2015-01-18 19-18-09.bin
Another suggestion, check your vibrations level, I had some issue in one copter and that was the problem
It did recover when you put it into Stabilize mode but then motor 1 went to idle and then to max?
This is where if we had motor feed back we could see what the motors did.
Mike
6
7
8
9
10
of 262 Next
