ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Nope, nothing was changed in the EKF tree. I fly a large tricopter 6s with 15" props, and 450 size V quad with pixhawks.
          for generally good flying make sure you do compass calibration every time you change literally anything on a copter, like changing gimbals, changing the place of your FPV gear, antennas etc... also, it is better to be outside and away from metal objects when doing compass calibrations.
          • What about changing locations? I asked Randy but I think he didn't see my post, do you do compass calibration when you change flying places?
            BTW I did like 10 successful 10min+ flights this weekend in a different location where I did my compass calibration and it flew perfect, I'm finishing my yaw tuning but my tbs discovery it's flying like never before :D
              I agree with Artem.  There should be no need to re-do the compass calibration when you move to a new location.  It is necessary when you change the orientation or location of the compass on the copter, replace the compass itself or add metal bits to the frame.
              • So, when I add FPV to the copter I have to redo compass cal? I frecuently change cameras to my copter, that can affects the compass? Thank's
                • some pilot cams have metal cases, I have a camera which has plastic case, but its mounting bracket is metal, so yes anytime you add any metal parts or change position of the current metal parts you should redo your compass calibration.
                  • If you put a magnetometer app on your phone/tablet and hold it a similar distance between your compass and your camera you can see just how much effect it has. I suggest one that displays field strength in uT for 3 axis rather than just a compass. It can be used to check out how magnetic your tools are too.
                  • Thank's for advertise; I'm waiting a metal case camera for FPV.
                  • MR60
                    Even your camera in a plastic case will influence the magnetic field (your camera electronics has an impact on EM fields), so yes it is best to redo compass calibration.
            • no, not really unless you are traveling 200-300 miles...  but i found out that it does affect my compass calibration when I added the gimbal and relocated the flightcam.
  • Randy,
    Another Log from 3.2 rc12 on Tarot 650 quad with following specs:
    APM 2.5 (no external mag)
    SunnySky 4110S-25 340KV motors
    HK Multistar 45amp ESC running SimonK firmware
    Props - 16x5.5 CF
    Battery: 6S 5000mAh Zi[ppy Lipo
    Was flying in AltHld mode when suddenly quad just started assending on its own.  Please check out the log file and advise...
    Video: http://youtu.be/GSmQVkWbWJ8
    2014-10-11 16-15-34.log
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
