Arducopter starts to circle and crashes
Hi there
Today my copter crashed after some fpw flying while parked in loiter mode (10/15m alt). It started to fly circles (aprox 5m diameter) and suddently picked up speed and circled down...
Luckely there was no damage because I managed to slow it down and level the copter before impact.
I checked the logs of the flight, and there sems to be kind of oscillating in the roll_in / roll and also in pitch_in / pitch values... easy to find, just graph this values and the baro_alt.
As I said, I had parked the copter and was checking the screen, the radio out of reach.
Has anybody an idea what caused this circle inputs? Would be very greatful for any suggestions or solutions!
TD:
copter is a a 650mm quad with HD3542 motors, 13x4 blades, with equipment aprox 2.8kg.
regards andreas
2013-02-24 14-20 8.log
  • Hello!
    I have the same problem.
    Have you eliminate yours?
  • Hi, my hexa has been flying Ok for the last 4 months, have not changed anithing but FW, now it takes off and hovers Ok until I touch rudder (level mode), then it starts to spin and ocilate.  Changed my PIDs and have reached a point where right rudder won't generate much trouble, but right input will result in spining right and oscilating, have made it to land relativley safe, but I can´t keep on flying like this.  Any ideas? I have calibrated compass meany times, even upgraded to the new GPS -Compass combo but it behaves he same.  Please help me.
  • I had the same issue & it was attributed to Loiter Speed and Rate Loiter.
    I've found that if I vary even a small amount from their sweet spot I get the copter going into an increasing diameter spiral whilst picking up speed. So obviously tune your other stability values as per the tuning guides first.
    FYI my values on a Quad are;
    Rate Loiter P:4.0  I:0.04  D:0.4
    Loiter Speed P:2.0  I:0.0
  • Hi Mike
    Thanks a lot for yor reply. If checked the tunig and lowered the Roll / Pitch I value a bit and he copter flies now better in Stabilize.
    About the problem, it seems to a magnetometer issue, see:
    http://diydrones.com/forum/topics/arducopter-crash-help-needed?comm...
  • Hi Andreas,
    You are the fifth or sixth person to describe similar behaviour before a crash in the past few weeks.
    None of teh developers seem interested in responding to anything posted outside the '2.9 release' discussion.
    You might have more luck posting there.
    Just from my quick look at your log (uneducated guess) the copter seems to be struggling following inputs. If you check out Pitch-in to Pitch and Roll-in to Roll you will see what I mean.
    Are you running the default parameters for 2.9.1?
    Have you been through the tuning guide?
    It may be just out of tune parameters exacerbating a deeper problem.
