This morning, I finished soldering my Ardupilot Mega and the IMU Shield.
After a visual check up, I connect the IMU to the computer through the USB connector and a few leds went on both on the IMU and on the ardupilot.
The computer recognized the new device and installed it.
After a few minutes checking the arduino software, all the leds went off on both boards.
Then I verified that the fuse on the IMU was very hot.
Then I did some tests:
1- If I connect the IMU to the computer without the ardupilot board, the leds on the IMU goes on like this: power led on all the time, rx and tx blinks a few times and go off. No other leds turns on regardless of moving the board. The fuse on the IMU stays cold.
2- I f I connect the IMU to the computer with the ardupilot, no leds gos on and the fuse on the IMU heats.
I don't know what happened with the ardupilot mega board after a few minutes of use...
I also checked the board for shorts, using a multimeter, but I didn't find any pin in shot with other beside.
Could someone help me with this problem, please :-( ?
Thank you
My best suggestion...being one of those who is optically challeged myself, Invest in a really big magnifier and look those boards over closely. There just has to be a bridge somewhere on the board.
Good luck.
Thank you
