Ok got all the bits together, programmed the ardupilot, no shield, uploaded successfully version 2.2.2 or 2.2.3 On reset Status LED flash once, power LED ON. GPS EM406 plugged in, 406 LED off (glowing faintly) but no GPS Lock LED flash. The Status LED blinks few times per second.Any ideas?RgrdsSarel
the first time I powered up my ardupilot (w. shield, EM406, set in sirf mode, V2.2.3), the gps led light was on, the board blue led blink and then went solid. Gps lock was very fast. Tryed several times with success (gps led off, very fast lock, about 30").
I mounted then the ardupilot on a plane with a 40cm long gps cable connected on the 4pins 5v shield.
No more locks (gps status led off, blue led always blinking).
Tryed to reconnect it on the original gps socket.
I feeded the system with 5.955V (don't know why my Skorpion esc is stated at 5V, but deliver 5.955V). As suggested by Jordi, I already switched to an other esc that deliver 5,15V at bec.
Now the questions:
- is the cable lenght (40cm) the problem (cable continuity already checked an working, I have 5v on Vin, Tx and Rx end)?
- do I broke something by feeding the unit at 6V?
- wich other problem could be there?
Thanks for help.
Ric
That's totally weird. No blue LED at all with jumper off. I'm on the road and don't have the hardware in front of me but will try to recreate your setup. I presume you've got all the RC stuff connected (Rx and servos) as instructed by the manual. If you don't have the Rx connected, the code won't run properly.
Sarel,
In your last comment, in parentheses, you show the Protocol set to 0.
Line 1-7 in the header file should look like this:
#define GPS_PROTOCOL 1 //0 = NMEA, 1=SIRF, 2=uBlox, Choose protocol, uBlox only for PRO's please.
You need to set your 0 to a 1.
Now the questions:
Thanks for help.
Ric
