Arduplane 2.28 and Arduino IDE version 1
I recently updated to the latest Arduino IDE version (previously using v22).
When I was  loading up Arduplane v2.28, I found some of the files generate compile errors, due to the changes from the earlier IDE version.
I had copied all the Arduplane v2.2.8 library files into the Arduino IDE library, but errors when compiling the arduplane.pde file included :
"wiring.h"- no such file or directory
"WProgram.h" - no such file or directory
"boolean" - has not been declared
also "unit8_t" is also generating errors
When I swapped back to V22 of the Arduino IDE the files compiled perfectly.
Any clues, or will there be a new version coming out shortly to address the Arduion IDE changes?
Thanks in anticipation
Randal
  • I am having the same issues. I have tried using Arduino 1.0 with and without the -relax option and am still getting the same errors. In the source code it looks like it should be calling wire.h rather than wiring.h but I honestly do not know what the issue is. The ArduPlane 2.30 is still giving me these issues so if anyone has any ideas please let me know.
  • Are you using the 1.0 compiled with the -relax option from the APM repository?
    http://code.google.com/p/ardupilot-mega/downloads/detail?name=ardui...
