Attopilot voltage with seperate BEC
I have a seperate BEc to power my APM.
In the attopilot setup instructions in the mission planner it says I should measure my ESC voltage and subtract 0.3v from it get the correct voltage calculation.
What's the procedure if using a separate BEC?
    The same procedure is followed if you connect the BEC to the PWM outputs side.
    If you connect to the PWM inputs, don't subtract the 0.3Volts
