Auto Analysis error message in Mission Planner
I have been using Mission Planner for 2-3 years without problem. Recently, after downloading data flash log via Mavlink  and reviewing the log, I clicked the Auto Analysis button m and got the following error message :--
                            The type initializer for "NumpyDotNet.NpyCoreApi" threw an axception
After I clicked OK, got another message saying :"Bad input file".
  MP version  1.3.35
This happens on Arducopter 3.2.1,  Arduplane 3.2.3, on both my desktop and laptop, and on both APM2.6 and Pixhawk.
  • I've just started having problems with Auto Analysis , I am using MP v1.3.39, Arduplane 3.6
    I have only recently started using plane, but I've used arducopter for 2 years without problem.
    MP does load an older log from plane 3.4 but my latest logs from 3.6 I get "bad input file".
    I initially wondered if my log file was corrupted but I've loaded them ok in "review a log"
    And the kmz file loaded also.
    plase update to the latest MP.
    • @Michael,
      thank you for your excellent Mission Planner, excellent tool for  Drone Crash Investigators with FAA
      BTW1
      I exactly got the same error, so Auto Analysis is down for me.
      Maybe the case is log file from one build is not fit to open for another build.
      BTW2
      How to set ranges to fit selected charts ?
      Sometimes, selected charts are out of group range (left and range ranges)
      I recall screenshot of MP charts supporting multi-column ranges to the left, each featuring color to match charted data.
      Only yesterday I studied drone crash and GPS.Alt and Bar.Alt charts didn't match the preset range.
      I was told GPS.Alt was all above 1,000 m and Bar.Alt was up to 10 m in altitude.
      Sometimes I get GPS.Alt.Rel to match Bar.Alt data range.
      BTW3
      Yesterday I played log file from another drone crash and got no GPS.Alt refresh
      in Google Maps window.
      GPS.Alt got updated clicking Play/Stop Play/Stop Play/Stop
      Ok, old 2GHz PC, and disk is almost full, Windows XP.
      BTW4
      Any chance for MP manual as a single file ( Word, PDF format) ?
      If I live on off-line PC, I don't have an opportunity to read manual on-line or click wiki every time.
      My congratulations.
      Excellent job, excellent MP, you should be honored by Secretary Foxx, FAA, White House, NSA, DARPHA, for what you did for the individual drone hobbyists to let them fly safely
      and study every drone incident like a Profi.
      Be my friend.
      darius
        I will answer based on your numbers above
        1. there was an issue with the older version of MP, with a dll error about numpy, it is now fixed.
        2. with graphs depending on how you select them they can be graphed on different axis. ie left click on, vs right click. in the dataflash log viewer you can add data modifiers to bring data inline, do this by double clicking the entry in the tree view
        3. was the problem there on other pc's as well. (just trying to find out if it was because it was a slow pc, or if it is a bug)
        4. currently there is not. although with the recent changes the wiki is being moved to GitHub, so there maybe some changes in the area.
        Michael
        • Michael, I am also having issues with Auto Analysis:
          MP ver 1.3.37 bld 1.1.5917.13431
          Pixhawk: APMCopter V3.3.3 (acf2e10c)
          MP running on windows 7 environment
          Downloaded logs, select "Auto Analysis" and navigate to folder where my log files are stored I get the following error:  "Error   Could not add reference to assembly mtrand.dll".  After receiving this error message I select OK, and I get the message "Bad input file".  Does not matter if I select log or .bin (bin is converted to log without an indicated error).
          2016-04-18 09-25-16.bin
          https://storage.ning.com/topology/rest/1.0/file/get/3702813477?profile=original
          • Hi Michael
            I have been using Mission Planner for more than 3 years Its a great GC it does everything we need from set up analysis to mission planning but i notice on the latest release the abasulute function has been removed how do i get it back i notice if i place a way point with verify height on it will place the first way point at the default altitude then the next one is placed ASL which is what i need
            Thanks in advance and hope i am not asking this in the wrong place Sorry i sorted it out if you verify alt first it works
    • Thanks for reply.
      MP 1.3.35 build 1.1.5878.12941 which I am using is the latest version, I believe, as I checked for update in the HELP section of MP, and it came back saying there is no update.
      Any other clue that you can suggest ?
      Thank you.
Aug 25
