Hi all,
The APM 2.6 in auto mode cannot seem to get the plane (wing wing z-84) down to the target cruise speed of 12m/s.  During missions in still conditions it flies at 15-20m/s. Stall speed is 6-8m/s.
I am not using an airspeed sensor.
Some parameters are:
Stall prevention is OFF
Max throttle: 40%
Cruise throttle: 25%
Cruise air speed: 12m/s
Max air speed 22m/s
Min air speed 8m/s
Originally I had TECS_CLIMB_RATE set to 2 m/s and the plane cruised even faster (25 m/s). I changed this to 10 m/s and it slowed it down to 15-20m/s.
Can someone please advise me on how to tune the plane to achieve the desired cruise speed in terms of parameters to play with.  Even being an engineer myself its not the simplest thing to understand how TECS works in terms of all the parameters.  I feel there should be a parameter to change if your plane cruise speed is over shooting or undershooting.
Lastly, I am not comfortable with my max throttle being 40%.  Id like it to be 100% but that will make the plane fly even faster while cruising.
Thank you,
Jon
  • I have the same problem with nearly the same Plane (Bormatec Ninox) without Airspeedsensor.
    Will it be possible with APM Planner to use the groundspeed to set the right speed. If I use "do_change_speed" in Mission planner it doesnt work. I hope it is only a bug in mp( as I founfd in the web). But does my apm plane (Arduplane firmware 3.7) allow me to change the speed (based on groundspeed) without Airspeedsensor?
    But anyway, when I have the choice between Arspeed and groundspeed it should work! I hope!
    I am actually using the plane in very high altitude (4.500 m m a.s.l.) and it is way to fast in the thin air!!! i need to controll the speed.
  • How did you end up doing with this? does it fly well?
    Do you mind giving a close up image of all the electronics?
    • I think my min ground speed was set to 9000 which was 90 meters per second and meant it was flying as fast as max throttle will allow.  I don't have the plane anymore,  crashed during manual flying with a loop too close to the ground. There is a picture in my earlier replies of the set up. Basically had the hkpilot micro mounted in the wing just near the opening for the internals and the GPS was on the other side. Plane flew pretty well in auto and fbwa
  • I have this exact plane which I have set up as a mini-FPV aircraft. It's a lot of fun, flies well and most importantly is small enough to throw in the car for whenever I have an opportunity to fly.
    As with your setup, I don't have an airspeed sensor, as there is not much room to fit one.
    My understanding is that when an airspeed sensor is not used, the throttle % is the method the autopilot uses to control the speed of the aircraft. Changing the target airspeed probably won't have any effect. While the autopilot does calculate an airspeed estimate, even without an airspeed sensor, it would be dangerous to rely on it so I think the code just doesn't.
    Your only real option is the change the throttle % target. You can do that in parameters or via a do_change_speed command in a mission (set the first parameter to 1 to indicate throttle %).
    Hopefully a developer can chime in, but that is my understanding of how it works.
    • They are lots of fun and very convenient, and cheap.  The air frame in the picture supplied actually split in half after a meeting with a tree (when I was a bad pilot) and it was so easy to glue it back together and it may even fly better.
      I have read up on a lot of the wiki and I did suspect without an airspeed sensor that that airspeed target might not be used.  I've also read about the TECS pitch and throttle methods for achieving flight speeds.  I do wonder if they are used if no airspeed sensor.
      I guess if a developer could confirm the parameters which are meaningful without an airspeed sensor that would help a lot. Also how the TECS_CLIMB_RATE and MAX throttle percent work together (if they do).  I read something about a linear relationship between what pitch/throttle.  i.e. max pitch = max throttle.
      Thanks for the advice James, I will give it a try.
      • The Max Throttle is a hard limit that will never be exceeded during autopilot. The Climb Rate is a target and it is used for planning so the autopilot can predict its best climb rate. For a max performance climb it will use max throttle and you will get whatever climb rate that gives you.
        You need to tune the TECS so that climb_rate coincides with Max throttle. Set your max throttle that you are comfortable with, then look at your logs to see what climb rate that gives you. Do it on a 50% battery. Same with the descent. Put the plane in the maximum throttle off dive you are comfortable with, (with a stable airspeed).
        If you take the time to set the flight envelope via the TECS parameters, the plane will fly much better.
        • This is very helpful. Thank you.
          I wish it was clearer what parameters to change with or without airspeed sensor.  Mission planner should grey out parameters that are not used depending on what configuration you have.
    • Agreed. No airspeed sensor means the airspeed Params are not used. Just adjust the cruise throttle % to adjust cruise speed.
      • Hi iskess,
        Thanks for your reply. If I adjust it to say 20% in no wind conditions, will the autopilot adjust throttle if there is high winds? Ie if there is a strong head wind, will throttle increase to maintain any ground speed or something if there is no airspeed sensor.
        • I don't know exactly what the code does, but I have oserved the throttle being modulated in response to ground speed (wind). Most of my airplanes have airspeed sensors because I find the autopilot behaves better.
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
