Autonomous "Vertical" Missions In Mission Planner?
Greetings: I am using a 3DR X8, Pixhawk with a NEX5 for standard mapping/photogrammetry. I want to map a cliff face. Is it possible to create an autonomous flight in Mission Planner that will photograph the face in a grid-style pattern up-down and left to right (or vice versa) with the same kind of image overlap that you can do on a vertical mapping project? Think photogrammetry turned sideways to map in a vertical plane as opposed to the normal horizontal plane.
I can use a gimbal set at 90 degrees and create the waypoints fairly parallel to the face but can't figure out the up/down part at a specific waypoint. I have seen this done with oblique images that are manipulated in specialized software (EG PIX4D) but not with images taken parallel to an object in an 'up-down' format.
All help gratefully appreciated and accepted.
Marshall
  • Did you ever figure our a good procedure for vertical face mapping?
    Thanks for posting
  • I haven't flown a copter for a while (mostly fly planes) and I do not have SITL handy but I suggest you try it out in SITL first. If you haven't set up SITL yet, check it out here, it will save you a lot of time when trying to figure things out.
    SITL Simulator (Software in the Loop) — Dev documentation
  • Andreas, I'm not really familiar with that command (seems more for planes than copters); will take a look at it.
  • I think what you might be looking for is the LOITER_TO_ALT type of waypoint in MP.
  • Hello Everyone.
    I've been investigating for a (relatively) simple, reliable, and "all-round" planning tool or method to use for vertical structures, landslides, cliffs, power-lines, etc.
    - Using Mission Planner (free): I implemented something similar to Felipe's approach, where you basically use an essentially manual "copy-paste" method to create/replicate parallel way-points (or lines of) at different altitudes - I've not flight tested though - @Felipe: have you field tested these kind of missions? And what do you think in terms of safety and results?
    - Using Tower (free): the Structure Scanner feature can be used for buildings (or objects for which circle surveys are adequate); pretty straight forward to set-up and use.
    - Using QGC (free): I have not looked into it, but I feel MP and Tower are better; please advise otherwise if you know.
    - Using UgCS (non-free): I'm investigating if the ONE license ($65) has the more advanced planning tools that allow "vertical" mission planning; it would probably be the most user friendly, safe, and complete, at least that I know of.
    It would be nice to have some sort of guide on this topic - I make myself available if anybody else wants to join resources/experiences.
  • Hi everyone,
    Guys, I think I figured out the vertical wp problem...
    At least, for my aplication it's enough...
    In flight plan, I add all way points that I need, after, I copy the coordenates (lat-long) that I need for all of waypoints... after I set the altitude for each one. All of the points will be at the same position and what will be change in flight its just the altitude, where I can set the command that I want.
  • i am also interested in this question ... some news ?
  • Has anyone figured out a good way to map a vertical surface? Ideally we could use a lidar range finder to maintain a constant distance from the cliff wall.
  • I am also interested in this capability, to conduct repeated surveys of the condition of tall structures as a way to estimate future maintenance or repair projects.
    • Any developement? That should be a great add for Tower app. Maybe easier than the circle survey, omho!
DIY Robocars via Twitter
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
10 hours ago
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
15 hours ago
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
15 hours ago
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Monday
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Monday
Monday
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
