Pixhawk, Arduplane 3.2.2.
Hello guys,
having a problem to make EKF to work.
As soon as I put the EKF_ENABLE 1, the massage "BAD AHRS" appears on my Mission Planner screen. I couldn't find any similar topic on other forums so you're my last chance =)
I thought that it's might be a hardware problem, but both of my Pixhawks acts the same. The IMU pin legs connections on PCB are also look fine. All the initial calibration were made.
I also had an idea that it might be a wrong EKF_ or AHRS_ parameters problem, but I varied them without any successful result.
Both IMU seems to work according to log file. But most of EKF'1-4' logs shows zeros. Since it was recorded indoor so I turned off the "AHRS_GPS_USE 0", but even with its on and outdoor the result is the same - "Bad AHRS"
I also noticed that INS_PRODUCT_ID turns to "0", saying that IMU is unknown, but not 5 as it should be for Pixhawk.
Please help, I spent the 2 days solving this problem without any results!
Here are the Parameters and Logs.
Hello guys,
I found relation between power-up time and the "Bad AHRS" message.
Each time, on power up, the Alt readings on the Mission Planner Tuning window shows few centimeters variation.
After about 8 minutes, still on the ground, copter not armed, the Alt variation becomes about 5 meters. Same effect I have on both tested Pixhawk controllers.
The picture is enclosed.
Hi Guys,
I had the same problem with my Y6 copter AC3.2.1 and now with the AP3.3.0.
I tried 2 different GPS modules, redone the accel calibration, compass calibration. if I wait for 10+ minutes the message goes away, I also tried SKIP_GYRO_CAL, NUT NO LUCK!
Can anybody shed some light on why this is happening? and how to correct it? could an optical flow system correct it?
I would happily fall back to 3.1.1 nut as I understand the terrain following is not in that version.
Nothing to do with terrain - AHRS is Attitude and Heading Reference System. The only way I've solved the message so far is to keep the Pixhawk/airframe absolutely still while rebooting and/or re-do accel/imu calibration.
Thanks Graham!
Every time I do the calibration my horizon ends up approximately 30deg tilted. If I reboot i get "bad AHRS".
Does "Preflight calibration" include gyro/IMU calibration?
I was asking if 3.1.1 has terrain following already in it as a separate question. I could have a forestry job around some hills, but without terrain follow capability I cannot do it.
Preflight calibration doesn't include IMU calibration. Are you doing the 6 sided IMU calibration?
Sorry misunderstood the terrain question. I can't remember if 3.1.1 is using terrain following, we're using 3.2.1 which is pretty solid and proven so far. I have an issue with APv3.3 so not using that ATM. Maybe a complete reset (flash other firmware) would fix that 30° roll error?
Has anyone tried 3.3.0 beta to see if the bug has been fixed?
We started getting this and a reboot usually sorted it out however a 6 way gyro/accel re-calibration seems to have fixed it properly.
This week I'm working to solve the BAD AHRS problem. I had the same problen than you.
Finally, i solved the problem using the Ardupilot V3.1.1 version.
Have a nice day.
Starting to get this too, sometimes a reboot helps other times not. Did you ever solve this?
