So i did some testing on the i2c port and its reading more then 3.3v so know I have to change the voltage reg and see if it fix the Bad Gyro Health issue.
I once bought a HK clone and it came up with that message.
If you left it sitting while plugged into the GCS, the artificial horizon would move on it's own. Slowly at first but eventually picking up speed until after an hour the horizon line was spinning like a top.
Have you tried re-flashing the FW.
If you have then most likely You have a bad board.
Paul Vang > Mike BolandDecember 20, 2014 at 11:41am
I'm still new to this hobby. Can you explain what GCS and FW is? I would appreciate it.
Mike Boland > Paul VangDecember 20, 2014 at 11:46am
GCS - Ground Control Station
FW - Firmware
If you ever have troubles with a board one of the first things to do is reload the latest firmware.
You will do this from your Ground Control Station being something like APM Planner or Mission Planner using their firmware update screens.
Then try re-calibrating.
Paul Vang > Mike BolandDecember 20, 2014 at 6:54pm
I have APM 2.5 with HIL firmware. After reloading the firmware again on my APM 2.5 board, I'm getting Bad Gyro message on hud.
Could be a 3.3v reg , or if you have it connected by usb and your computers 5v rails isn't up for it
yeah i've read
It means exactly what it says.
The Gyros are not healthy.
FW - Firmware
okay I'll do that.
