Hi All,
I'm not sure if this is the forum to place this, but it just might be interesting to some of us..
A while ago I was waiting for having my car-tires balanced when I thought that must be possible with my motor-prop combination as well.
So what I did...
Got an old 9DOF razor board from Sparkfun, a motormount, a laserpointer, old transistor uses as light sensitive element, ESC and some programming skills and assembled this into a "Dynamic outrunner and propellor balancing Unit".
The razor board is equiped with an 8 MHz Atmega 328 chip that drives the ESC and reads the light sensitive transistor. Communication to a PC application is done by serial I/O
How it basically works:
- connect the razor serial port to your PC running the visual basic application.
- place the outrunner with propellor mounted on the stand. This stand is flexible mounted on the wooden base plate.
- mark one blade of the propeller with a marker. With each succesive balancing-run this marked blade should be on the same starting position.
- on the pc-application click the "RUN" button.
- now the motor runs from 1000 to 3000 RPM while the accelerometers on the razor board are constantly read. The measurements are sent to the PC-app.
- this pc-app shows the place where a counterweight should be put. It also kind of indicates the mass of it.
Done this several times to test the system and till now it works very well :-) I noticed that not only propellors need balancing, but also the outrunner itself. Could just be poor chinese quality as well :-(
All video's I shoot with my quad are without any halo-vibration-effect since and the quad is vibration free.
What else did I do:
- motors are mounted with shock absorbing supports.
- I removed the circlip from the outrunner-axle. This not only makes the balancing action very easy (just pull off the propellor unit) but also saves the bottom ball-bearing from excessive wear. I know some people may say
this is dangerous, but I never experienced a lost propellor. Every 50 flying hours I replace all bearings with quality european bearings.
Config:
motors: 4 X KDA 20-22L from Hobby King
Prop: APC SF 4,7 * 10
APM 1.4 Hotel & Oilpan with selfmade MS5611 baro-modification
ESC: Turnigy 25A basic 3.1 met simonk firmware, all calibrated manual
3DR radios 900 Mhz, HF decoupled by ferrite ring
sparkfun compass removed from frame by Starship Enterprise construction, shielded cable
Ublox LEA-6 GPS
RX/TX 40Mhz Robbe/Futaba F14 8 channel, ch5:6-way diy-mode-switch, ch6:potty, ch7 extra switch
No sonar
Lipo 4000 1p3s
2 X ubec DE-SW050 Fixed 5V switching regulator(http://www.dimensionengineering.com/products/de-sw050) both with 220uF, 10uF tantal and 100nF parallel. One system for apm + RX, the other for, leds, 3DR radio
4 Ledstrips, discrete driver 2n2222 (yes, leftovers from the stone age)
quad made of: carbon en forex (= foamed PCV). The carbon arms are two crossed rods of 1 meter each.
motors on flexi mounts
apm, dampening with 2 millimeter neoprene + aluminum.
Powerboard: diy 2 * Y, wires to motors not yet twisted, but no effect on compass
No bullet connectors to ESC and motors, all soldered
Camera Canon A3300 with CHDK hack for interval shots and RAW images, even movies are good (love it)
Camera gimball: some chinese carbon thing, works well. 2 X Hitec HS-322HD servo
Total weight: 1.8 Kg w/ camera & gimball, Flighttime 10 min, without camera 12 minutes.
Size M2M diagonal 75 cm
See attached files for pictures and pc app screen dump
Off course, I'll be happy to share code and more insight information if anyone is interested.
I just sit down for when have enough time to build one
A set up Video would be nice, confused?
I had similar issues at first. Watch this video and start with the settings they used, then tweak as needed. The windows application still crashes on occasion but much less often if I use fewer sample runs.
http://youtu.be/eWWOqcSu8IY
After asking Frank a few questions I took a shot at creating a wiring diagram in Fritzing. I'm posting this mostly for comments. I am a noob and have not tested this yet. I created this hoping to get feedback before I start building one of these for myself. As soon as my IR sensor arrives I plan to test this set up.
This is great stuff. I would need some help on the hardware setup of the motor mount and where to place the accelerometer on it or underneath, etc
What parts do you use for building the motor mount (or stand)?
What are the parts list of hardware needed to build this myself using your program?
Thx
Sounds great! I kind of dropped that idea because I thought I would need to balance at flying RPM, rg. 10000, and I found no accelerometer that could make a sample within, say, 30 degrees = 0.5 ms. I might not have looked hard enough...
Regards
Soren
Hi Frank,
As stated in your post, are you able to share the source code for this? Looks like a great project which I'm sure the kind people on the forums can contribute to.
regards
fanman
Frank FYI, the software seems to be working as I can load and review the samples (getting a "could not find ... smp.meta"). This project is just what the doctor ordered to reduce my blood pressure - while attempting to balance prop and motor combinations. Thank you for all your efforts and for sharing results. Looking forward to further developments (hardware and firmware). Bob
Hi Frank ,
Great work ..any news in this development ? this very very interesting ...please keep giving news
regards
Fernando
1
2
3
4
of 4 Next
