Hi All,
I am looking for best performance LIPO battery for the 3D Robotics Quad-C frame kit (I bought the unassembled version - gonna assemble it this weekend).
My Configuration is (Default 3DR):
4X 10" propellors
4X 850kV Burshless Motors
4X 20A ESCs
Standard 3DR Quad-C Arducopter Kit
I would like to know the best LIPO battery to use for this combination. 2200mAh, 3S OR 3000mAh 3S OR something else? I want it to fly 15min without any camera/ camera mount. I am confused about the combination with 2S, 3S OR 4S also.. any suggestions?
Regards..
Don't go for the minimum C rating you can get away with. The lower the C rating the hotter your battery will get. And I'm sure you are already aware that when your battery gets hot you are wasting energy heating up the battery! So the problem is actually more complex than you have described it. A higher C rated battery is more efficient (heats up less) but is heavier. You can use less of your stored energy to heat the batter but you will need to carry more weight to gain that efficiency. Higher C rated batteries are heavier.
Mike
Remember to start slow and fly low for the first few flights. Keep your controls in stabilize mode and learn how to fly.
Have fun and fly safe.
Richard
