Big X8 Strange Behavior
Hello to all
I  build a big X8 and i suspect some think happen with my rc mapping when  octo starts  it feels unresponce  with  big corrections  and hard landings result and some flips whatever i do  in P doesn’t  affect  the system  so my next think is the rc mapping  i use sbus futaba  receiver  direct pinned to pixhawk  but my rc in  and out in channel 12 and  4   look strange also  the roll and dess roll looks opposite
I enquiry the LOG
Any comments are welcome
https://youtu.be/VW37goiZcRg
3691261205?profile=original
39.BIN
  • MR60
    With such a big prop and low KV configuration, your PIDs are way too low and you craft is a bit underpowered.
    You should ideally hover at 50% of throttle. In your case you barely get the required throttle to hover (minimum 14Kg) at above 60% of your throttle.
    To solve the issue, you either reduce the size of your props (motors will spin faster) and increase your PIDs significantly.
  • Please show detail information on your X8; motors, batteries, weight, and propellers.
    • kde 27,6 x 8.9 props
      U10 Motors 2 x 22Amp batteries
      Tiger motor 60A esc
      14 kg full without payload
      Really guys you think is an underpower setup?????
      at 60% i must have  12 kg  of  thrust and in 100% 22kg how is possible to be underpower
      • Are you using 6S? For such low kv motors, you need a very good reactivity. If you can secure 1 motor with its props and try to shake your throttle stick you could check response time of your Esc/Motor/Props. If too slow, you can somehow compensate with high PIDs but you may experience problems in flight.
        Large props = more inertia, with low kv motors as yours, you do need a prop that follow very well throttle outputs. Regenerative braking helps, maybe you could try KDE ESCs?
      • also after further investigation  in raw data looks motor 1 ,7 and 8 be asynchronous in stabilize motor  and with no move on frame   please see video here
        • The link to the video is broken...
        • I had a similar problem with a big quad and slow big props. I had to increase rate P and use a lower STB_P/R value (something like 3 maybe) to limit the angular speed of the copter. At the end I changed the hardware setup: motors were just not reactive enough to accelerate large props.
          May you tell what motors/props combo you are using?
    Antonis,
    It seems like the vehicle is under powered.  Maybe the KV of the motors is too low?
    The reason I say this is that when it's flying the motors are at >80%.  You've probably noticed that during take-off you need to give nearly full throttle on the transmitter?  For good performance a vehicle really should hover at absolutely no more than 70% and really under 60% is best.
    3702145636?profile=original
    • 3702608283?profile=originalalso from previous log without change everything and with crash again  look my throttle in and out i attach  the log also  i think is very strange with the same setup have so big difference  propably esc not work correct ???
      • log file is here
        24.BIN
        https://storage.ning.com/topology/rest/1.0/file/get/3702728921?profile=original
