Board does not go into RTL or Waypoint mode
Hello, I have a problem that my Ardu Pilot board doesn't do anything when I turn the toggle switch. Neither the Mux LED nor the Mode LED ever went on. With the oscilloscope I was able to mesure that a signal is coming in the ATtiny but no matter how wide the pulses are nothing comes out at PB1 and PB3. I reprogrammed the Attiny, but that didn't help. But since I can program the ATtiny it should work.Does anyone have an idea?Thanks greets simon
    What RC system are you using?
  • Hi simon,
    I had similar problems with failsave V1.6, now with failsave V1.5 my Ardu operates normaly.
    Regards, Michel
    Is the board powered on? Are your servo plugs in the right way? Maybe you have a borked board....that's a Sparkfun issue.
