Am looking for building a Fixed Wing UAV for Aerial mapping and performing it based on my own research. Your suggestions are most welcome to correct myself in building it.
AIM
To assemble a Fixed wing UAV for Aerial Mapping with 2.5 - 3 hours endurance
REQUIRED PARTS
1. Skywalker X8 (2122mm) airframe
2. TURNIGY Plush 60amp Electronic Speed Controller
3. Aeronaut CAM carbon 12x6.5 folding prop blades, Aeronaut 36mm Precision Spinner for 5mm shafts, 38mm Aluminium centre piece, Folding Propeller Blade Stopper
4. X8R 8/16Ch - FrSky S.BUS ACCST Telemetry Receiver
5. Digital Air Speed Sensor And Pitot Tube Set
6. Turnigy TGY-225MG Analog High Torque Servo 26g – 2
7. Turnigy Aerodrive SK3 - 3542-800kv motor
8. Pixhawk 2.1 autopilot
9. Taranis X9D Plus transmitter
10. HERE GPS
11. 22,050 mAh Li- ion battery – 2
13. Carbon Fiber sheet (1 Roll – 4 x 6)
14. Balsa Wood
Hello... excellent build, i am a late joiner, building my 1st Skywalker X8, have bought most of the needed components, abou some stuff i am confused.
what size carbon fiber rods should i get to reinforce the wings, will 1mm be sufficient enough or 1.5mm
and what is the thickness of the carbon fiber sheet youre using, i dont want to accidently order a really thick one.
and can you kindly post a wiring diagram i am having issues, i am also using the same Pixhawk 2.1
thanks, will wait for your reply
Are you using pre-preg carbon fibre sheets that just need to be ironed on?
also how have you mitigated / what issues if any have you encountered with RF attenuation due to the carbon fibre shielding film?
TEST FLIGHT - 3
Description:
Z-poxy)
Analysis- Test Flight 3 (1):
Analysis- Test Flight 3 (2):![3702438921?profile=original](https://storage.ning.com/topology/rest/1.0/file/get/3702438921?profile=original)
TEST FLIGHT - 2
Description:
Z-poxy)
Analysis- Test Flight 2 (1):
Analysis- Test Flight 2 (2):
TEST FLIGHT -1
Description:
Analysis:
Downloading Log Data from Auopilot
3.Under the tab, Download Dataflash Log Via Mavlink option selected. It opens a dialog box which shows list of logs save in autopilot based on date and time.
4.From the list required log selected by checking check box and Download Selected Log option selected.Log Downloading indicated by green bar rising at the bottom of the dialog box.
5.Finally download will be completed. Log files will be saved to the computer.
Loading Log File into Mission Planner
Hi Rodrigo,
We chose X8 cuz of the performance it will give in terms of speed and flight time, also the spacious fuselage is one of the reason as we can experiment with more components/payloads.
We get the telemetry data in our Ground station during flights. You can find more information on Pixhawk 2.0 in ardupilot page. There isn't much information available for pixhawk 2.1. We haven't finalized the selection of RTK and its accessories, so it will take some time to conclude on the RTK. But, yes we plan to use RTK for survey accuracy. We have Here+RTK, Piksi Multi and Emlid Reach as options. Pix4D accepts the log file from AutoPilot/GPS during the processing. You can refer Pix4D documentation website for more information.
Stay tuned!
Rodrigo Valdelomar said:
Hi Pragadish,
Adding RTK sounds awesome. I plan to use it for crop surveying so RTK it's not my main goal but it might be helpful. I'm actually planning to add solar panels to be able to have way longer flights.
Anyway I'm a rookie so i have a lot of research to through.
Would you mind explaining a few of your set up choices? I really want to learn more in order to apply it to my experience.
I know those are a lot of questions but i would really appreciat it if you could help me out.
Thanks a lot!
Hi Rodrigo,
Actually the purpose of going for custom built drone is to improve the accuracy of the results by adding RTK/PPK GPS in future and also to increase the flight time for more area coverage.
Keep following my posts and do recommend me on improvements.
Hi Pragadish Santhosh I'm reading all of this from Argentina.
I find it really interesting since i have the same idea as to build a fixed wing for mapping. I'll keep on reading as you go forward with the project.
I have a few questions, why did you decide to go with that custom set up instead of using something like the CHUCK from a parrot disco? I'm quite new at these and i couldn't find anywhere why Pixhawk set up is better than using something already integrated.
Thanks and best of luck
15) Problem With Airspeed Sensor
16) ELEVON Plane Settings
2.Mixing Gain
The MIXING_GAIN parameter is critical for elevon aircraft. It is the gain used in mixing between roll and pitch output and your elevon movement. For example, if your MIXING_GAIN is 0.5, then the following outputs are used:
By adjusting the MIXING_GAIN you can quickly setup the right throws of your elevon aircraft.
18) FBWA mode Check
Input
Action
Roll right
Left elevon goes up and right elevon goes down
Roll left
Right elevon goes up and left elevon goes down
Pitch down
Both elevons go up
Pitch up
Both elevons go down
