I did some searching and didn't see an answer:  Basically can I bind 2 air radios to a single ground radio?  I will only be using one at a time.
Currently I have a single ground/air radio and I'm buying another APM for another platform, so I wanted to a second air radio for that platform so I don't have to switch out radios.   Will this work, or do I need to buy a second ground radio as well?  (They're all on the same band of course).
  • I have a similar question:
    Can I use multiple air radios with a single ground unit at the same time?
    I would like to control a handful of drones from GCS.
    Mav link can use up to 255 devices from what I have read, but I dont understand if I would need a 1 to 1 ratio of air to ground units or if I can use many to one?
    From the radio perspective is this possible?
    From the code perspective I know it needs work.
    Thanks!
  • You can set 2 air radios with same parameters.
  • Presuming you're talking about the RC side of the operation, absolutely...that's how transmitters with multi-model memories function. :-)
Aug 25
