Can someone explain ROI a little bit?
This is what the wiki says:
DO_SET_ROI
Yaw tracking optionALtitude (in meters)LatitudeLongitude
  • Setting will persist until reboot
  • The location is optional
  • The option is a number from 0 to 4
  • MAV_ROI_NONE = 0: Yaw will hold it's current angle
  • MAV_ROI_WPNEXT = 1: Yaw will point at next WP
  • MAV_ROI_WPINDEX = 2: Yaw will point at the desired WP at the index #
  • MAV_ROI_LOCATION = 3: Yaw will point at the indicated location (The location in the command)
  • MAV_ROI_TARGET = 4: Not implemented
But in the mission planner, there is Command, P1, P2, P3, P4, Lat Lon Alt.
How do I fill these boxes in to get my XCopter to point at a ROI? For example, launch, fly to an area, set the XCopter to face a location while navigating a course, then return the Xcopter to normal facing (forward?), and continue on to the end of the mission. In other words, do a fly-by with my forward facing fixed camera pointed where I want. I think this is what the ROI command in mission planner is for, but I can't find the details on how to set it.
  • That's awesome. Which flight controller did you test with?
  • I just figured it out!
    To use this, right click on the map and "Set ROI". Duh!
    I'm heading out to test.
  • I'm guessing nobody has tried this feature?
