Hi my name is deepak
I'm using pixhawk to trigger my canon sx230 hs using chdk on ch7 on pixhawk
while doing auto missions i'm noticing the number of pictures taken by camera is not equal to the number of times pxhawk has triggered the camera, the number of photos is most of the times more than the no of photos the log file says,
im using these circuits in between pixhawk and camera
3691207143?profile=original
  • I think you are missing the ground wire between the BEC and the - pin on the Pixhawk. See this: http://www.flyingeyes.ca/turnigy-receiver-controlled-switch-wiring/
    The Pixhawk only has a 3.3 volt output on the signal wire. I couldn't find the specification sheet for the Turnigy but that could be a problem.
    Marco's circuit here works well: http://diydrones.com/forum/topics/using-aux-pins-as-relays-for-chdk...
    Turnigy Receiver Controlled Switch - Wiring Setup
    The Turnigy Receiver Switch is a neat little piece of hardware (tiny!) which allows you to turn things like LED lights On/Off from a free channel on…
    • Hey Phil Simpson,
      I've done the common ground wiring from pixhawk to the circuit,
      used this ciruit after the SparkFun 5V Step-Up  converter didn't workout,
      also the triggering is shown in mission planner hud,user items Ch 7 out, pwm changes from 1000 to 1900 set value,
      Thankyou.
      • Seeing the Ch. 7 PWM change to 1900 means everything in the Pixhawk is set up correctly, that's good. But it could still be a problem with the 3.3 volt output. Try connecting the Turnigy switch directly to the output of a radio receiver powered with 5 volts. If it works there but not on the Pixhawk then it's not compatible with the 3.3 volt PWM. I've had that happen to me on an IR trigger. If it doesn't work, then you have a problem with the Turnigy. I fixed my problem with the IR trigger by putting two diodes in series with the trigger power supply, that made the power supply voltage and PWM voltage about the same and it was happy.
DIY Robocars via Twitter
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #14 - #ParkingLotNerds join us January 15th for #AutonomousRacing #RoboRace ⁦@DAVGtec…
Monday
RT @chr1sa: And after that came our races, 50 in all. This battle between these two Russians was the best we've ever seen -- incredible fig…
Monday
RT @chr1sa: Before our @DIYRobocars virtual race this weekend, we had a presentation from the team that won the Indy Autonomous Challenge i…
Monday
DIY Drones via Twitter
Dec 12, 2021
Dec 12, 2021
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Dec 4, 2021
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28, 2021
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26, 2021
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25, 2021
@gclue_akira CC @NVIDIAEmbedded
Nov 23, 2021
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23, 2021
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23, 2021
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20, 2021
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20, 2021
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9, 2021
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31, 2021
