After a failed attempt to do some mapping which resulted in most of the pictures NOT being taken, and the ones that were taken being very blurry, I went through my 3DR EAI S100 Lua script and found a lot of the settings had been changed. It has probably been a year since I tried to do any mapping and was disappointed that it didn't work like last time.
Having been through all the settings for the camera and the script that I could find here:
https://github.com/ArduPilot/ardupilot/tree/master/Tools/CHDK-Scripts/Cannon%20S100
I am left to wonder about the other settings in the CHDK menu's...
Do they also need to be adjusted? For example, I found that RAW had been disabled, and that Camera Delay was set to 2 seconds... Do they override the LUA script settings?
Are there are any other settings in there I should look out for? The menu's are quite comprehensive and exhausting to go through. I have been through them all but it would be great if the mapping pro's out there could give me any other tips on what to look out for...
For the record I am using a 3DR Quad 2014, Stock (Just ordered a new GPS Here) with Pixhawk, 3DR Radio Telemetry, Multistar 10000mAh 10C Battery, Custom Camera Control USB cable, Canon S100 mounted using a Gopro Mount with Camera thread adapter, Taranis X9D with Flight Deck and a FrSky Lipo Voltage Sensor.
UPDATE: Have just discovered the newer versions of KAP UAV 2 Lua scripts... Mind Blown ha ha ha
Am very excited to learn about the new PIXHAWK mode and that I can now get feedback from the camera when its shutter is opened giving greater geo tagging precision!
The next trick is to get the new PIXHAWK mode working and make that LED sensing cable - Anybody have further information on this circuit?
I don't want to buy the Tuffwing cable for $40.
Hi Stanley, thanks for your response.
I have no desire to use the Stock Canon firmware when I know the CHDK achieves better results.
Sandy Sound Helo, use this setting;
Camera mode : TV Shutter speed priority
Then go to Func. Set. to set the following.
ISO : Auto
Cloudy
4:3
JPEG only
FlexiZones
Am wondering if this Photoresistor is suitable for the LED Feedback cable?
Vishay BPW76A
http://uk.rs-online.com/web/p/phototransistors/8151248/
I have had trouble implementing the new "PIXHAWK" USB trigger mode in the KAP UAV 2 lua script.
These forum posts have been very useful for me in understanding the setup:
https://chdk.setepontos.com/index.php?topic=10822.950
https://chdk.setepontos.com/index.php?topic=13028.0
And the Tuffwing pages:
http://tuffwing.com/support/pixhawk_camera_trigger_cable.html
http://tuffwing.com/support/Install_a_canon_precision_geotag_cable....
Otherwise there seems to be very little info out there. If anybody has any experience getting this working with the latest APM:Copter FW your help would be greatly appreciated!
This is the best? circuit diagram I have found so far to build for the LED feedback cable:
What do you think?
