Hi guys,
When i try to flash the firmware to the board, i get the following errors. The first error appears as soon as i click on the Firmware button between simulation and terminal.
The error i get is when i try to select the OCTO firmware icon
Any ideas? Hoping to get a flight in!
Thanks!
Firmware.diydrones.com
hope that helps you
That's ok !) you have some other options, like down load custom firmware or previous version of the soft wear, on bottom right corner? If you choose custom firmware stick to stable versions.
