Hello everyone.
Today I tried to fly a small Cessna 182 with pixhawk and everything seemed fine until I activated the FBWA mode. I started flying manually and take off with difficulty because it is a little heavy, but when I thought was stabilized I activated FWBA and the aircraft went crashing to the ground. Reviewing the log I see that the commands I was sending to pixhawk were completely contrary to what I was doing with my radio.
I'm right ?? below the flight logs to see if someone can help me.
Thanks in advance
MarkM
Thanks for the information. Unfortunately when checking the control surfaces was in manual mode.
What other things should I check before starting the flight?
The manual has a lot of good info - start here http://plane.ardupilot.com/wiki/table-of-contents/. There are quite a few sections and it takes a while for it all to sink in (at least it did for me) so be prepared to go back a few times.
This section covers channel reverse in your radio and in the APM s/w http://plane.ardupilot.com/wiki/arduplane-setup/first-time-apm-setu...
The "First Time Flying Checklist" section includes the following statement (FBWA mode will work just like stabilize mode).
...."You should do this before every flight, just as you move your control surfaces with your RC transmitter to ensure that nothing’s reversed. Failing to do this is the #1 cause of crashes."...
Thank you
I've made the same mistake with my rudder, was fine in manual but as I was coming in for landing in stabilise mode ground steer kicked in and constantly veered hard right. Was a silly mistake that I haven't repeated...... yet lol
Generally I check the surfaces in auto modes and manual, check lipo voltage and my alarm is set, quick throttle check while plane is restrained. Thats after a range check (varies between rc tx's), will then check fpv gear if im using any and lastly, just fly the plane.
Have recently rebuilt my apm into my 1400 fms cessna 182 (dx8 crapped out on me, again!) Just finishing off the openlrsng install then back out for a maiden on 3.1
Dear:
I have noticed a strange behavior when I put full right aileron up and right down. It is as if the signal is maintained for a while and then fell.
Is this a problem pixhawk ?. This happens even when I have it in manual mode.
Thank you
This is a link with a video to show the problem
https://www.dropbox.com/s/ih0vaqgwqb5u91n/2014-09-16%2014.21.44.mp4...
What about the autotune? I read that should be done during the first flight. (that was today's idea originally)
