Cesna Pixhawk Crashed in FBWA . Autopilot wrong???
Hello everyone.
Today I tried to fly a small Cessna 182 with pixhawk and everything seemed fine until I activated the FBWA mode. I started flying manually and take off  with difficulty because it is a little heavy, but when I thought   was stabilized I activated FWBA  and the aircraft went crashing to the ground. Reviewing the log I see that the commands I was sending to pixhawk were completely contrary to what I was doing with my radio.
I'm right ?? below the flight logs to see if someone can help me.
Thanks in advance
2014-09-04 12-04-44.bin
2014-09-04 12-04-44.kmz
                • Thank you very Much.
                  I'm going to try and let you Know
          • This reply was deleted.
            • MarkM
              I think this Pixhawk properly configured.
              Here is a video with the theme to see if you can help.
              https://www.dropbox.com/s/83g35tlhhhfrz2l/Comportamiento%20Pixhawk%...
              Thanks in advance
              Dropbox - Error
              Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
                • The Cesna Crash First. This is another one.
                  Thank you very much for your answer.
                  I'm going to try and let you know.
    • Andre:
      I'm not trying to blame anyone, least to pixhawk. I'm just trying to understand what went wrong  to not make the same mistake again.
      I was not aware that I had to adjust the way FBWA, I thought it came preconfigured from 3dr.
      Also I checked the control surfaces before takeoff and everything was fine.
      Thanks anyway
        • MarkM
          Thanks for the information. Unfortunately when checking the control surfaces was in manual mode.
          What other things should I check before starting the flight?
          • The manual has a lot of good info - start here http://plane.ardupilot.com/wiki/table-of-contents/.  There are quite a few sections and it takes a while for it all to sink in (at least it did for me) so be prepared to go back a few times.
            This section covers channel reverse in your radio and in the APM s/w http://plane.ardupilot.com/wiki/arduplane-setup/first-time-apm-setu...
            The "First Time Flying Checklist"  section includes the following statement (FBWA mode will work just like stabilize mode).
            BEFORE EVERY FLIGHT: Before you take off, hold your aircraft in your hands and switch to stabilize mode, then pitch and tilt the plane it to confirm that the control surfaces move the correct way to return it to level flight. (The ailerons and elevators will move; the rudder only coordinates turns with the ailerons in flight, so it won’t move much on the ground). This will ensure that you haven’t accidentally reversed a channel.
            You should do this before every flight, just as you move your control surfaces with your RC transmitter to ensure that nothing’s reversed. Failing to do this is the #1 cause of crashes.
            • ...."You should do this before every flight, just as you move your control surfaces with your RC transmitter to ensure that nothing’s reversed. Failing to do this is the #1 cause of crashes."...
              Thank you
            • Dear:
              I have noticed a strange behavior when I put full right aileron up and right down. It is as if the signal is maintained for a while and then fell.
              Is this a problem pixhawk ?. This happens even when I have it in manual mode.
              Thank you
              This is a link with a video to show the problem
              https://www.dropbox.com/s/ih0vaqgwqb5u91n/2014-09-16%2014.21.44.mp4...
              Dropbox - Error
            • What about the autotune? I read that should be done during the first flight. (that was today's idea originally)
