Compass issues with AC 3.3
Hi
I am using AC 3.2.` on pixhawk and it works good.
When I uploaded AC 3.3 I got compass issues, I was getting errors compass variance
Also when I tried to fly , I almost crashed it, my tarot got very unstable and banked to left and right
any thoughts about it?
regards
tom
        • will try, but I am almost sure that the screws are the problem.
          before the mounting change, the offsets were around 50 - 100.
          I think that the steel screw could be your problem.
          At my frame, the next screw is around 5-10cm away.
          Maybe you can change the according screws to stainless steel v4a, brass, or aluminium ones.
          I have ordered the nylon screws and also v4a ones and will report back when I get them.
          I also use an external compass however, but I wanted to use the internal one for letting the EKF check plausibility.
          Did you check the AUAV at the bench?
          • I did have some issues w/ it on the bench, not mounted in a copter.  At the time, I was anxious to get it built, and didn't look in to it much.
            I just ordered some non ferrous screws, and will certainly try that!
            • I installed the screws, and the internal compass dropped from about 220 -50 -150 to about 150 -50 -150.  So, it did help.
              Doing further investigation, I discovered it's not my internal compass that puts my heading about 45 degrees off.. It's my external csgshop GPS/Compass...  When I use it, everything calibrates fine, but it is pointing off 45 degrees clockwise.  (when copter is facing north, the mission planner display shows it pointing north east)
              I found this post about the same GPS, and the compass being connected incorrectly on this GPS, but I'm not sure I believe him... Else, I'd expect more complaints..
              https://groups.google.com/forum/#!topic/drones-discuss/a_OIlaa6Z1c
              Google Groups
              Google Groups allows you to create and participate in online forums and email-based groups with a rich experience for community conversations.
              • Did you set up the right rotation for your external GPS/Compass in Mission Planner?
                I also installed nylon screws now and the offsets are still quite high..
                369 -154 238
                but a lot better than before
                • No rotation seems to be correct.  All the others give me big problems.
                  But, that is a confusing topic.  The magnetometer is upside down, on the bottom of the GPS PCB, but apparently "no rotation" is correct because the code expects the compass to be upside down.   It's definitely not rotated by 45 degrees.
                  I've got another flight controller and compass on the way for a different project.. I'll try to do some testing with this questionable compass while I've got it on the bench and everything is easy to access..
                  Worst part about this hobby is trying to figure out which components actually work properly, from the factory.
    • The values depends of the metal around the controller and the Pixhawk hardware itself.
      I have several Pixhawk, and each is different. Best MAG data (offsets are about 10) gives a clone Pixhawk, unfortunately the baro diverge a lot....
      The original 3DR gives more offset (105 61 43), but the baro is very consistent.
      Always measure the controller outside the frame, on a wooden table (no metal around). Then compare with the frame offsets.
      A get BAD AHRS usually when the baro values floats. Normally, in quiet closed environment, the baro (ALT) should not float much (+- 20 cm)  The same clone mentioned above, floats about 5 meters after 8 minutes power on!
      3DR controller I measured floats no more 20-30 cm in 1 hour.
    • Hi, I have 3 pixhawks and the internals on all of them have near those offsets. Not only that but if the calibration program is run successively, significantly different values are obtained. I also notice on dataflash logs the two mags when graphed diverge and converge. LSM303D strikes again (though it'd probably be fine if it were made external).
      Try disabling the internal and using only the external.
  • you need to post a log file for anyone to really be able to help
    • I understand, however, it has nothing to do with my drone, the issue is with the firmware, after uploading 3.2.1, it works.   so for some reason 3.3 is causing issues.
      Thank you
      • 3.3 has worked flawlessly for alot of us.. what have YOU done to try and resolve this issue ? Did you take ANY steps at all ? Help yourself a little for others to help alot.
