Compass mag_field hard interference: solved
I had really hard mag_field interferences compass in one of my custom copters (see Tridge analysis done in this other topic)
See the mag_field during a normal flight:3690923746?profile=original
The harness arrangement was done randomically inside the two main plates .In particular both red and black lines were independent (not good for mag_field!):
3690923817?profile=original
So, I decided to re-route the powerlines by substituting the old harness by independent highly twisted lines for each of the ESC´s starting from the battery. I´ve shortened also the battery cables to the maximum, and also twisted them a bit.
So the result is awesom: It complitely solved the problem (see second Image of a similar flight).
3690923904?profile=original
I hope this help others to solve in the root the eventual interference compass problems: lets "twist and shout"!
Angel
  • Dying to see some photos! I have been having some issues regarding Random Yaw on my X8.  Would twisting wire always be a good practice in main wiring for future reference? I haven't really studied my logs yet, too busy reppairing and balancing props.  TIA :)
  • 100KM
    That's very nice Dani !   Unfortunately twisting powerlines would require a complete dismantling and rewiring of my copter, which I really don't see me doing.
    Surely we can't expect all users with yaw problems to rewire their copter ?  It worked fine before (2.0.49) so we should be able to get it working fine again.
  • Hi all,
    prior to using 2.5.3 I ha no problems with yaw.
    With 2.5.3 yaw would have a will of it's own, wandering about 25º to each side; I believe it must be some kind of process that now is more sensitive to mag interference,
    So I followed afernan's advice, high-twisted all power lines and moved the mag a bit further away.
    Tested it today, and yaw is back to rock solid.
    Thanks! great tip!
  • Extensive flight test results with new hardware setup
    The goal is try to get the best offsets for the better flight. Also to compare the three method we have:
    1. Using MP / hand rotation , motors off
    2. Using MP / TLOG offline calibration
    3. Compass_learn by Tridge
    Method 1):
    hand rotating (no motors) -43, 30, 25   repeteated again   -30,31,17
    Method 2):
    Using MP / TLOG offline calibration. I´ve got three long fly records (see attached TLOGs)
    TLOG
    Thro>10%
    Thro>20%
    Thro>30%
    2012-04-02 20-17-35
    -21 31 76
    -21 31 76
    -21 31 76
    2012-04-02 19-54-08
    -14 34 64
    -14 34 64
    -14 35 65
    2012-04-02 19-00-45
    -17 36 89
    -17 36 89
    -17 36 89
    2012-04-02 20-17-35
    3692387029?profile=original
    2012-04-02 19-54-08
    3692386779?profile=original
    2012-04-02 19-00-45
    3692386927?profile=original
    Method 3):
    Compass Learn:
    Outdoor flight:
    After 2 min flight                   -2,40,-4
    After 5 min more                   -19,39,-14
    After 10 min more                 -18,52,-11
    After 15 min                           -16, 16, -95
    CONCLUSSIONS
    • Compass_learn gives very different values for "mz_off", but similar values for "mx_off" and "my_off".
    • Method 1 (hand rotating, no motors gives also similar values for mx, my but not for mz offsets.
    • So we can consider mx_off = 21 , my_off = 31 as good values since in all three methods are similar.
    • For mz_off I rely in second method, that is not so far than first method: let say mz_off = 65
    • A flight with this values confirms that they are good  (see TLOG graph 2012-04-02 20-17-35)
    Looking fordward your comments on this results to try to commint on one method for today until we get another.
    TLOGs.zip
    Nice one Angel!
    He was the one who flew avoid, but unfortunately it is inevitable ... "come on let's twist again"... :P
  • Very cool!  EMI issues are always a pain. Care to post a pictures with twisted pair harness?
    That's a great result Angel!
  • 100KM
    Great stuff afternan !
    Did it solve yaw problems you were having ? (if not, what symptoms did it solve ?)
    The thing that still bother me is this : with 2.046 till 2.0.55 I didn't have any yaw problems and my wiring was the same as it is now...
    Power to my hexa motors is done in a starburst form *.  A central feedline from the battery is split into 6 branches heading into each arm
    Great write up! Thanks for sharing this information. I almost wonder if this should be a blog post so more people have eyes on it.... Its good information for everyone.
    Thanks again!
  • Clarification:
    What I want to say for "independent highly twisted lines" is the following:
    From the battery I´ve created four independent lines black-red (- & +) driven to each of the ESC´s. Each pair of +/-  cables are highly twisted in order to cancel its own magnetic field by its own. This is done for each of the four pairs of +/- cables .
