Compass problem with 2.0.55
I've wiped my board (reset APM to default), then reprogrammed 2.0.55.  I have the compass and sonar, along with an XBee 900 pro for telemetry.  Removed the XBee, no change.  Removed sonar, no change.
The compass constantly reads in an endless loop of rotation, sometimes it changes direction after a reboot.  See the first 10 seconds of the youtube video below.
Previously when I enabled the compass in mission planner, it calculated my offset based on the GPS lock (at least that's how I remember it).  This time it didn't grab the declination until I entered the first three digits (14.1, San Jose CA) myself.
Level was set manually and works fine, pitch, yaw and roll respond normally, only the compass is whacked.  From the tuning (screencap below) I see the target_bearing go from 0-360 in an endless loop as well.
Worked fine in 2.0.49.  :-)  Any expert advice would be appreciated.
3690903685?profile=original
  • For what its worth, I had this same problem. I did not have any problem with the installation of .55 and I had terrible drift in the compass. I had to disable simple mode as it would be almost impossible to fly. if it makes any difference, I also did an erase and re-flash before I flashed .55
    after an upgrade to 2.1 now, the compass is very stable. Also I noticed the "level" in the mission planner is now actually level while in .55 it was not.
    I know we are all past this, but I thought more information is better then less.
    cheers all!
  • Same hard/software here. Mine does the same thing: very slow, continuous CCW rotation- but only inside.  If I take it outside for a minute or less its spot-on and tracks very fast- till I bring it back inside.
  • After loading 2.1 everything looks good.  Not sure what happened, but I will be back in the air soon.  Cheers.
  • Going back over the sequence of events, I'm pretty sure a programming failure happened. I last flew successfully on 2.0.49. When I loaded 2.0.55 mission planner blew up during programming. I was a little worried the APM would get corrupted, but I've programmed it successfully since, from both MP and Arduino IDE 0.23.
    A test shows compass problems but all other sensors respond normally. I presume the HMC5883L has firmware and it may have been corrupted.
    From MP I deleted all settings once, then programmed it with 2.0.55 alt hold patch from the A-IDE. I'll try 2.1 tonight, it was released 15 minutes after I gave up for the evening last night. :-p
    That looks to me like gyro drift that is not being compensated for by the compass. So it's not the compass that is providing the bad heading but rather the compass is not working and so it's not being used at all to offset the gyro drift.
    Of course you've enabled your compass through the mission planner or CLI menu right?
    Can you use the CLI menu to test the compass?  put the white switch towards the back, connect using usb, type "test" then "compass"
