I'm using the Arduino IDE. I have been working with ArduPlane version 2.63, but just recently decided to update to version 2.70. But, whenever I pulled in the new firmware and tried to compile i'm receiving these errors:
ArduPlane.pde:-1: error: new declaration 'uint8_t digitalRead(uint8_t)'
C:\Users\David\Documents\arduino-1.0.1\hardware\arduino\cores\arduino/Arduino.h:100: error: ambiguates old declaration 'int digitalRead(uint8_t)'
ArduPlane.pde:-1: error: expected constructor, destructor, or type conversion before 'int'
ArduPlane.cpp: In function 'int SKETCH_MAIN(int, char* const*)':
ArduPlane.pde:-1: error: 'OK' was not declared in this scope
ArduPlane.cpp: In function 'uint8_t digitalRead(uint8_t)':
Does anyone know how to fix this? I'm using the most recent Arduino (windows version) available in the Downloads section.
I have managed to compile the 2.7 code on OS X, but where do I find the compiled hex file?
Matt
I haven't had any problems compiling AP 2.70 when using the arduino1.0.3 windows version, provided on this website. What I am trying to so is find a Arduino version that will allow me to compile on an Ubuntu machine.
@David,
To compile ArduPlane v2.70 I think that you will need the Arupilot modified version of the Arduino IDE 1.0.3 which can be found here: http://code.google.com/p/ardupilot-mega/downloads/detail?name=ArduP...
You will need to set the flavor of your APM in the ArduPilot menu in the IDE header and then restart the IDE to compile.
TCIII
You need to use the custom version of Arduino v 1.0.3. Be sure and select the correct platform.
