Computer Requirements for APM Mission Planner.
What are the computer requirements to run APM mission planner?
Most of my computers are older running Windows XP. I have downloaded the support software listed in the guide. When I run the software I get google maps and the HUD but then the display freezes. I read where this could be a video card problem. Can anyone confirm this? Is there anything else required to run on an older computer. I have the same problem on a desktop and a laptop. I have a newer computer that is running Windows 7 and the mission planner is running fine there but I need it to run on these older computers too.
  • If you cant getto the he HUD tick box you can cheat:
    1. Open conf.xml in the planner folder in notepad
    2. Under the line that ends insert a new line:
    True
    3. Save the file (making sure your not adding a.txt extension to it) and restart planner. You may have to restart a couple of times but it should work as ive youve ticked the box now.
    D
  • Not sure if it is your problem, but in my experience it always pays to update video card drivers, and to keep windows machines up to date in general.
  • Stan
    I run Mission Planner on XP emulated on an old MacBook laptop. I was having same issue as you (really slow/screen not drawing full) but after ticking the HUD checkbox at the bottom of the Configuration-Planner tab all works really well now. If you can't see the Configuration Tab (i.e. is doesn't draw/is white) just click in that area until you get it.
    Paul
    3692295526?profile=original
