Continuous photo shooting for ArduPilot
Hi all,
I have a Skywalker X8 that I've been building for aerial photography (wildlife population management), and I'm having an issue with a way to trigger the cameras. The two cameras I have onboard the plane at a time can be triggered with a servo, as I don't want to open them up and mess with the switches. I have read in the ArduCopter forums that for some reason, the camera trigger option doesn't work except after a dummy waypoint, or something like that. It may have been fixed, no matter. I'm looking for something a little different.
What I would love to see in ArduPilot 2.69 or 2.70 would be a continuous shooting mode, where the APM will trigger a channel once every couple seconds or so for the duration of the flight. I know that most of the other aerial surveying platforms like the Gatewing X100 and the Sensefly swingletCAM use something like that -- they collect hundreds of images, one taken after another. Now, I'm aware that I could just take (low quality) video and use software to extract a high quality map of the area, but that wouldn't be optimal as the camera I have can't take higher than 320x240, which is terrible.
Basically, I'm looking for an option in the Mission Planner for a small piece of code to trigger a servo channel continuously every few seconds. Does anybody know if this is possible?
  • Can you just find a camera that does this internally? Seems a lot easier than a servo trigger.
    In theory, there is code on ArduPlane to support "repeating" EVENT/s with servos or relay, including how many times to repeat ( in your case  -2 means repeat forever ) , which rc channel to repeat on, and what PWM value/s to use for the action..... but I have never used it, and I have no idea how, nor if it even works.      look at the code here: http://code.google.com/p/ardupilot-mega/source/browse/ArduPlane/Ard... and search for the word "repeat" for a hint.      Maybe you can figure it out, and post a good set of instructions on how to do it?
