Contolling Altitude?
How does the ardupilto control its altitude? or for that matter hold altitude, is it using the co-pilot to make altitude corrections according to the GPS read out? Also how accurate would that be? Thanks any help would be greatly appreciated.
  • Alright thanks! Already bought the board and its on the way =) Are Ailerons neccessary? I was planning on modifying the wing to add them, but do I really need them? I was under the impression that the FMA needs them. I guess Ill know for sure when it gets here and I can read the directions.
  • Does the Ardupilot 2 use new hardware? Or the same hardware?
    I am planning to use ardupilot inside a glider which will be dropped from a weather balloon. So I don't have throttle to control my altitude which is why I am curious how it is implemented now. I am assuming I will need implement my own altitude control to monitor my speed and control what altitude I need to be at since I wont have a motor.
  • I am still a little confused about this. Perhaps someone can walk me through an example. Say the aircraft just reached a way point at 500 feet and the next way point is at 400 feet. How is the altitude controlled to bring the plane down 150 feet? The FMA is just a stabilization unit right? It just tries to keep the plane in level flight?
  • Throttle control Altitude changes and Elevator control Speed changes
  • ok, that makes sense, thank you very much for all the correspondence...
  • I'm pretty new to the game, been flying radio control planes for a while though. You say that it used the throttle for altitude control, does this use standard aerodynamic laws regarding lift vs speed? or does the elevator actually get used? Sorry for all the questions.
    It control altitude with throttle, based on GPS altitude readings. Accurate +- a few meters.
  • Sorry I meant Controlling
