Control Arducopter with PWM signals from Raspberry GPIO
Hi All,
I'm currently trying to control my Quadcopter (APM2.5) by emulating PWM Radio signals from my Raspberry GPIO pins.
I want ot use my Raspberry as a decision maker + controller, just telling the arducopter to go up/down front/back, left/right according to informations computed in the raspberry (USB camera + laser as rangefinder to begin)
I have been able to read incoming PWM signals using a simple arduino script that you can find at the following :
http://ghowen.me/build-your-own-quadcopter-autopilot/
Using the Rpi.GPIO library I have been able to generate PWM signals via python (using the following instructions, f=50Hz, T=200000us, burst from 1000 to 2000us)
http://raspi.tv/2013/rpi-gpio-0-5-2a-now-has-software-pwm-how-to-use-it
Next step, send PWM signals to the APM whith Arducopter installed on it.
I've been trying to "arm" it using a simple script (corresponding to low thr, right yaw), based on the values of min/center/max acquired during calibration but no joy...
Is PWM signals scripting via Python a good way to control my Quad?
Any idea why I can't arm my quad?
Many thanks
  • I figured it out myself at last -  with servoblaster it works *if* the dedicated 2 "HW" PWM pins are used on the RPi between specific ranges - I was able to calibrate the input channels with signals of 10% to 78% on 50Hz. Under 10% and above 78% the ardupilot does not interpret the input correctly. It's not a rocksolid solution as sudden changes are not properly handled - some dampening must be implemented to do a kind of smooth transition between two values. It is important to connect *only* the ground and the PWM signal PINs between ardupilot input and RPi and then start playing around with values on servoblaster. RPio is a more elegant solution but writing the /dev/servoblaster makes sense as well.
  • Hi All,
    I'm new to connecting raspberry to ardupilot and have some difficulties around the PWM so I'd like to ask here instead of open an unnecessary second thread for same topic. I also
    understood above it will have some fluctuation but I'd use it for a slow ship so I would not mind.
    Till now what i have done is generating PWM signals with servo blasterwith following parameters:
        Servo cycle time:            20000us
    Pulse increment step size: 10us
    Minimum width value: 50 (500us)
    Maximum width value: 250 (2500us)
    This was enough to move a tiny servo so I thought I'm good to go to connect this PWM output+GND from raspberry
    to Ardupilot's input. Unfortunately I cannot see my PWM signals taking effect in the calibration screen of APM.
    Would you be kind to please comment how can I improve - like using different timing values? Could it be maybe the voltage levels
    of Rpi as I read they do 3.3V instead of 5V only? Unfortunately I do not have a scopeish stuff to figure it out on the easy way.
    Thank you for helpful comments in advance
  • Connect USB or telemetry to APM, and check what values it sees first, also, did you calibrate or set max/min channel values?
    • Hello Andre,
      I dit that at first to calibrate the values but I think I know where the problem is,
      The PWM signal sent from Raspbery GPIO is not as stable as it should be, for instance with a 1200us burst, the value in the APM calibrating tool fluctuate from 1190 to 1210... I have tried to change the PWM frequency to 51Hz and it's better, but still fluctuating.
      I think that sending PWM signal from the raspberry GPIO is not a good idea...
      • no, that's too bad, you will not have smooth control.
        Consider using something like this: http://www.pololu.com/product/1350
        or programming your own microcontroller/arduino that can take input from i2c  or serial.
        • I2C is my second option.
          There are many sources about how to generate I2C signals from the raspberry.
          Do you where I can find documentations about I2C/Ardupilot?
          Will I be able to "control" the APM via I2C protocole?
          Many thanks
          • AFAIK, Raspberry is I2C master only, and APM does not contain I2C Slave code.
