Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Pormaroli,
The tune on roll looks a bit suspect but pitch looks ok. Can you provide a log?
So i just maidened ac:3.3 on my Y6. Flew great! Except for one exception, well two really. But the second one is not an ac3.3 issue, just a satellite issue.
First issue: It seems as though every time i plug in my birds I get BAD AHRS errors. This has been happening since 3.2 for me on 4 separate frames and configs.
Second issue: Seems like I was about to have a flyaway when about 3 feet off the ground. I was between my car, and my house, and a big building, so that is to be expected. But i thought EKF would catch that before it happens? It started flying off at about 30 degrees when i hit stabilize and full throttle to get it out of danger. It went about 30 feet horizontal before i hit stabilize.
When is UAV/CAN going to be enabled? I really want to try this zubax that has been sitting on my shelf for 6 months.
Cheers! And thanks for all your hard work and efforts! I appreciate it!
I will be testing 3.3 next week. Thanks Randy and team for all your hard work.
RB
@RB,
We have some UAVCAN support in this release including support for some experimental UAVCAN based ESCs. Tridge is the one who has been testing out UAVCAN for other sensors so I'll ask him about the UAVCAN GPSs.
Thanks!
I am interested in testing the zubax as well. It would be perfect if the zubax compass would be supported as well.
I'm putting this answer here so everyone interested could see it. Here's the tutorial that explains how to make APM use UAVCAN-interfaced sensors, particularly Zubax GNSS.
Can the same principle be applied our custom EPM which myself and Andreas are working on? (which will have UAVCAN).
Thorsten,
Have you tried to implement your Zubax with 3.3 yet? I have tried with no results. Zubax indicates CAN bus communication and GPS lock but the pixhawk can't use the data, so I'm not sure how Tridge set it up to work and have had no response from Dev team. I contacted Pavel at Zubax as well and I think he is looking into it.
RB
Ok, so Tridge has tested the Zubax GPS and it "works nicely!" it seems so feel free to give it a try and report back!
I connected my Zubax GPS, LEDs on the zubax are lit but I get no GPS signal through to the Pixhawk or indication in APM Planner. I can't find anything in the parameter list that looks like a UAVCAN parameter or to direct gps signal.
443
444
445
446
447
of 449 Next
