Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • just a feedback...I flashed the firmware, I haven't changed anything on my setup, just the firmware. Upon flashing, I cannot control my Alexmos gimbal's pitch. The Alexmos board is connected to the Aux1  port of Pixhawk which is programmed for the tilt control. It was working on AC3.2.1 before, but after flashing, the problem was there. I reverted to AC3.2.1 and again I can control the pitch. I tried to reflash AC3.3rc1 afterwards, but the problem persists. I used to control the pitch via RC6, the Gimbal is configured before in AC3.2.1, Can you help me please?
    • perhaps I need to rewire my gimbal to pixhawk... Can somebody enlighten me about the serial interface? i believe I am using the PWM setup, with RC9 (Aux1) connected to the Alexmos gimbal RC_pitch..
      Or it would be better if I can still use PWM for the RC pitch of the Alexmos BGC..
      • Anyone else having this problem?
  • WARNING to TradHeli users:
    Do not attempt to fly AC3.3 until you hear otherwise from me.  I have not even bench tested it yet, let alone test flown it.  There are quite a lot of changes that have gone in that could be crash-o-matic for helicopters.
    AC3.3 release for Tradheli is likely to be delayed.
  • Upload Copter 3.3 to replace the 3.3 dev (debug bad accel health, but IMU2,Dropix, etc,etc...)
    Needed 3 upload to manage the 3.3 installation.
    Seems to work great, little windy day (5Km/h), auto-tune is great, same result on the PID as VP Kuisma and others but seems to work fine, the Quad is fun to fly, even if, for the moment, only one battery for auto-tune and PosHold and...RTL
    aggressive PosHold flight is great.
    I'm really happy with the Ardu, great work! far away the best!
  • I'm looking forward to trying the 'new and improved' Auto Tune; just finished a quad that's a bit overpowered and wobbles like a weeble on descent. 3.2.1 AT gave some crazy results.
  • Re: "require the vehicle's accelerometer calibration to be done again" If I go up to 3.3 rc1 to do a test, when I go back to 3.2.1 to operate will I need to also redo the accelerometer calibration so it's compatible with 3.2.1? Or, having done it once with 3.3 rc1, is it good for 3.3 rc1 and 3.2.1?
      Phil,
           The accel calibration values are stored in different eeprom locations for AC3.3 vs AC3.2.1 so as you switch between versions, you'll see the accel calibration values switch to what they were when you last calibrated the accels using that firmware version.  So once you've done the accel calibratoin for AC3.3, it should be safe to switch back to AC3.2.1 without having to re-do the accel calibration again.
  • Is the increase in the number of Do_Jumps permitted from 3 to ? included in this release?
      Phil,
      Yes, the max number of do-jump commands has been increased from 3 to 15 for the pixhawk boards in AC3.3-rc1 (and higher).
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
yesterday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
