Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      @heliroberto,
      It's there, just click the beta firmware's link on the MP's install firmware screen.
      • Hi Randy, when I look at beta firmware´s in MP than I see only the 3.2 !!!
          Yes, I also see V3.3-rc1.  Maybe try updating your version of mission planner.  Also you must be using a Pixhawk but that shouldn't matter because the MP doesn't know what board you have when it's not connected.
            FYI: You need to be using the Beta version of Mission Planner in order to see V3.3-rc1, otherwise it shows up as V3.2.
            Nathaniel ~KD2DEY
        • I do see rc1 in mp, you can get version you want from firmware.diydrones.com.
      • I only get v3.2 when I select beta versions in the MP.
  • I don´t know if this is right place for suggestion for improvement. Is it possible to make two failsafe for battery? I like to have one safer limit and use RTL and if battery get critical I like to use Land.
    • Place your request here.  This is where folks place requests for fixes, or enhancements.
      You can also ping DEVS at Drone-Discuss but only for serious discussions.  This location is where the collaboration takes place between developers.
      • Thanks:) I am new with drone but now I have setup enviorment so I can compile firmware by my own and maybe start to help adding functions.
  • Hi all,
    All my apologize for my first comment but, last Sunday i did a auto tune, that seems to pass well.
    by the end of the auto tune, the quad seems to fly well, i finish my battery by a RTL, every thing seems ok, when i return to my housework, had a look on PID, and find similar result as a lot people here.(ex: old rate pitch P:0.31, new:0.088... strange but why not)
    Yestreday evening nice weather, let's have a flight! 2 min in the air, quad is unflyable!?
    I saw that the autotune is not ready, but what misunderstand is why i manage to complete autotune, test it on sunday and yesterday nothing go right?
    it's like if it don't turn on the new PID values by the end of autotune (according to the auto tune process), and write the news  PID value only when i disarmed it, (and stay on the old ones during the test of news ones)
    if it could help:
    Autotune flight log:
    https://www.dropbox.com/s/51xn25628p2pyw1/2015-04-12%2018-14-22.bin...
    Bad PID flight:
    https://www.dropbox.com/s/z9dvo6q5c1tg4u8/2015-04-14%2019-12-26.bin...
    Dropbox - Error
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
yesterday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
